Got some camry rims from a buddy and had them machined in the front to fit. Put the back ones on non machined and the left driver one wobbles...........gona pull it off today and check. Any suggestions?
Found it Found out it was the head of a bolt between two studs on the drum. Is there any bolt size I might be able to adjust to that has a flatter head
Really Yehi was guessing it was that, but we just also noticed it needs to be machined out cause the lip won't slide into the rim since their off a 2wd car. I got the frionts machined to fit now gotta do the rears. What about a small spacer to clear the lip on the drum
You can use spacers, a lot of guys use them to fit 350z rims. Its best to get the hubcentric spacers with the studs on them, but the samllest ones are 1" i think. The universal ones work but is kinda risky
Yeh the spacer I wanted to use was a 3/4 not big just to bypass the lip on the drum. I'll just have them machined and see what that does
