Some Problems Fixed
Discussion in 'Interior/Electronics' started by TRUCK ACTION, Sep 17, 2016.
  1. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Rolling into last weeks show the temp gauge was going up,found that when I turned the electric fan on it didn't come on, then found damage at the power distribution block in the cab over the battery. There was a lose wire to the fan controller that caused the readout panel & a fuse holder to burn!
    Got a replacement block & all is good with that problem!!
    And then there was the squealing drive belt that has been for way too long, when I ordered the alternator I had a smaller pulley made as I have under drive pulleys , the belt was riding at the bottom = the noise. Changed out pulley from a 2 3/16'' to a 2 11/16'' with corrected grove! Problem fixed!!
  2. Litneon
    Cocoa, FL
    94 xtra cab
    Geesh! That could have been way worse in the end. Glad you caught it.
  3. Orlando Muniz
    Orlando Muniz Veteran
    Pflugerville, TX was Sac Town, CA
    89 Toyota Pickup
    yea that could have been bad!
  4. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    All is fused & the fuse did pop after getting hot enough to burn the read out !
