after removing the right fender to address some rust that is causing a leak into the cabin I noticed an issue with the gasket for the wiring for the headlight and turn signal. In the picture you can see that the antenna and wiring share the same hole but the antenna does not use the gasket. is this how your pickups came from factory? To me it seems it causes an awkward fit and was wondering how everyone elses is set up. Thanks!
antenna is supposed to by by its self going through that little black grommet underneath the big main one its poked through now.
