Mono leaf vs drop leafs
Discussion in 'Suspension/Chassis' started by Radchadtrinidad, Dec 9, 2014.
  1. Radchadtrinidad
    Radchadtrinidad Member
    Anchorage, Alaska
    86 pickup
    Do you guys prefer mono leafing or think a 3"-4" leaf spring would be better because it's a better ride since there leads missing? Which would give a lower drop?
  2. Gr8KornHolio
    Gr8KornHolio Veteran
    Dallas, TX
    85 regular cab longbed 22R
    I went with the lowering leafs, needed it to still function as a truck and haul stuff from time to time. They probably give you about 3" once they're broke in and settled.
  3. 1lowSr5
    1lowSr5 Addict
    In the garage
    90' xtra cab Sr5, 2003 taco
    If you can avoid a mono leaf dont do it. The chance of a leaf spring breaking that way is very high. If your wanting a cheap 3" drop go with drop blocks. JMO :waytogo:
  4. jetas
    Or find some 4x4 leaf packs.
  5. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    3" drop blocks are really cheap. Soo cheap their cheaper than replacing a broken leaf pack because someone decided to mono leaf their truck and broke them. They are easy to install too. :waytogo:
  6. jjmartinez1987
    jjmartinez1987 Member
    Glendale, AZ
    1995 Pickup
    i know this is old but is middle leaf removal the same as mono leaf?? my bigger question is do the drop leafs maintain spring rate?
  7. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    "mono" as in single leaf spring.
    I believe with drop leaves you will lose some weight capacity as I believe the spring rate changes with those vs standard leaves. You could always supplement with other devices such as airbags, air shocks and coil-spring shocks.
  8. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    yeah, monoleafing is dangerous and stupid. I run drop leafs, which are basically stock springs, just de-arched. that does make them softer, so I went with variable rate load bearing shocks that had coilovers on them to compensate.
  9. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    No to the Mono leaf
    Use dropped springs & angled blocks
    jetas likes this.
