Leafs and Blocks
Discussion in 'Suspension/Chassis' started by Deliverm3, Aug 5, 2016.
  1. Deliverm3
    Deliverm3 Newbie
    I was looking to order the full belltech lowering kit that comes with spindles, blocks, and shocks. But I also was looking at the rear leaf springs.
    Will adding the leaf springs lower the truck in the rear more or is it redundant with the blocks already installed?
    Also, does anyone have experience with the belltech shocks? I was thinking about getting the kit without them and installing the KYB monomax instead.
  2. maxpowers95
    maxpowers95 Member
    BayArea (510)
    93 ext.cab 2wd
    its not redundant, both the blocks and lowering leafs will give you a combined drop of about 3 inches for the leafs plus whatever size block you get.
  3. Deliverm3
    Deliverm3 Newbie
    Thanks for responding! The kit has 3 inch blocks and the leafs are 3 inch so from what you are saying it would be 6 inches lower?
  4. maxpowers95
    maxpowers95 Member
    BayArea (510)
    93 ext.cab 2wd
    You got it, keep in mind that if you lower these trucks about 5 inches or more, you need to consider notching the frame since the axle will be too close to the frame.
  5. Deliverm3
    Deliverm3 Newbie
    Good to know, Thank you!
  6. LAYNLOW
    LAYNLOW Veteran
    Amherst,VA
    93 Toyota Pickup 2wd
    Not disagreeing with maxpower but i have 4" blocks and 3" lowering leafs with no notch....BUT i also have airshocks in rear so i can raise it up if its too low which when the airshocks are fully let out i do hit frame on axle on big bumps...with just lowering shocks i feel certain id have to notch
  7. Deliverm3
    Deliverm3 Newbie
    I will probably start with blocks and get my wheel set up going before I go too low and they don't fit.
  8. LAYNLOW
    LAYNLOW Veteran
    Amherst,VA
    :waytogo:
