Functional truck drop??
Discussion in 'Suspension/Chassis' started by l2ewind, Apr 11, 2017.
  1. l2ewind
    l2ewind Member
    Fort Collins Co
    1977 Hilux
    So, I just recently slapped on a new set of wheels and tires on my truck. Looking to lower it front and rear. How functional would the truck still be with a drop. I assume the front drop wouldn't matter that much but the rear would affect my load capabilities. What drop procedure should I follow to still have the same load capabilities as stock?
    Thanks!
    JC
  2. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    I've go belltech drop springs out back with Monroe variable rate load carrying shocks, and I have hauled loads of slabs 8' long above the bed rails with no problems.
  3. jetas
    Blocks alone dont change spring rate or anything. You might just bottom out quicker with the bed loaded. Throw air shocks in
  4. Juicyy
    Juicyy Member
    Norcal
    1993 single cab 22re 5sp rwd
    can you tell us what monroe part number you used?
  5. Justin Danger
    Bay Area Peninsula
    Sure! they were Monroe 58645 shocks. The bushings that come in the shocks won't fit our trucks, so I pulled them and put in some Energy Suspension urethane bushings #8141g. RearShocks.jpg
    Keep in mind these shocks are much shorter than stock, and should only be used with drop springs, not with blocks.
  6. Justin Danger
    Bay Area Peninsula
    Also, as you can see, I have stock bump stops. I did end up drilling a 1/2" hole through them to soften them up a bit. Now I don't have the awful bang clunking of when I ran drop blocks and gabriel load adjust shocks and would hit the bump stops regularly, I don't really even slow down for speed bumps much now.
  7. l2ewind
    l2ewind Member
    Fort Collins Co
    1977 Hilux
    I've been doing a bit of research and have decided on drop leafs from belltech, but I do have a few questions. I read through Justin Dangers build and his installation of his drop leafs. His year model pickup is newer than my 77. The leafs are intended for a 79-88 model year truck. I went through all the info I could find and nothing denotes that they would work for my year truck, that being said the rear axle dimensions on the pickups between his and my 77 should be very similar. Do you guys see me running into any problems? I have the Moog OEM Mighty max coils to swap out the stock ones on my p/u. I would really like to do front and back in series. Your input is greatly appreciated.
    Belltech lowering leafs
    http://www.belltech.com/products/be...ech-79-88-toyota-pickup-3-rear-drop-5976.html
    JC
  8. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Had no problems while I ran static dropped, axle hit the frame so went ahead with the 8'' notch as knew I'd be bagging her soon. Rode like this for a few years , bagged for over 7 years now & all is good,
    Roll @ 4.5 '' off the ground , lift her in & out of driveways & over speed bumps!
  9. Isaac Johnston
    Isaac Johnston Newbie
    Cheney Washington
    1978 toyota Hilux
    Hey guys I have a 78 Hilux lowered with 4inch blocks in the rear. I need air shocks for the rear. A part number would be much appreciated! (I've looked into the Monroe MA-792 air shocks but they're sold out everywhere. Looking for a good alternative to those) Thanks!
  10. jetas
    Check rockauto
  11. Isaac Johnston
    Cheney Washington
    1978 toyota Hilux
    Any specific part numbers?
  12. jetas
    How did you lower the rear? Just blocks?
  13. Isaac Johnston
    Cheney Washington
    1978 toyota Hilux
    Yeah 4 inch blocks, but I plan on going a lower in the future if I can.
  14. jetas
    I ask because the air shocks that are for these trucks dont compress to a smaller height. With blocks only itl be fine, if you start messing with the leaf packs then youll need something shorter
  15. Isaac Johnston
    Cheney Washington
    1978 toyota Hilux
    For sure. I ended up going with some ma-812 air shocks. Hoping they fit. And hopefully I'll have time this week to install them.
  16. Collin Ramos
    Collin Ramos Member
    Did you end up trying out those drop leafs? Did they work?
