fuel gauge not working
Discussion in 'Interior/Electronics' started by y0ta_man, Jan 4, 2011.
  1. y0ta_man
    y0ta_man Newbie
    San jose CA
    90 longbed 2wd 22re
    my gauge is all hooked up in the back of the cluster. it reads full for about 40 miles or so i would say then just drops to zero gas i dont get it
  2. Nook
    Nook Addict
    oregon
    Sounds like possibly the sending unit inside the tank is bad, the winding on the sender the floats rubs up and down on to read the resistance may be worn, worn through, or broken :shrug:
  3. oldschool64bus
    oldschool64bus Veteran
    Boise, Idaho
    1983 SR5 4x4
    truth, my old 77 had a spot right in the middle where the wire was broken, gauge worked till it hit the half mark and then dropped to empty. I just lived with it and filled the tank after so many miles.
  4. y0ta_man
    y0ta_man Newbie
    San jose CA
    90 longbed 2wd 22re
    NOOK how would i go about checking the read is there a way to get into my tank???
  5. Nook
    Nook Addict
    oregon
    Your gonna have to drop the fuel tank to access the fuel sender unit, on the newer trucks like yours (88)? there should be 2 cover plates on the top of the tank, the smaller one is the sending unit, the larger the fuel pump.
    You would use an ohm meter to check the sender resistance as the float is moved up and down to determine if its good or bad.
