who carries them in the correct size? my truck had a set in the rear but the shoulder size was a touch to small so they would spin when taking the wheel lugs on or off. no clue how the PO let that fly but whatever, im fixing it asap. but for now im running a 6mm spacer on stock studs... not sure i want to drop $150 on 1.25 inch spacers like i have up front but might do that instead if i cant get the correct wheel studs and sit the wheels a little more flush to the fender.
onto better judgement, im not even running the rear spacers. up front im catching part of the control arm (15x8 with a 25mm offset ) so i reused the 1.25 inch adapters for now
Been kinda wanting to do this as well arp makes them to but unsure on the length for the Toyota application .but my Honda ones were 3 inches long stuck out of my open ended lugs about a inch
yea it doesnt bother me if they were like the honda ones and stuck out a bit. when i had my srt-4 i ran extended studs upfront and they stuck out past the wheels by only a 1/4 inch, not as bad as the hondas lol. Ill look into them, thanks. you wouldnt happen to have a part number would ya?
