Drop blocks?
Discussion in 'Suspension/Chassis' started by _Rigo_, Apr 11, 2018.
  1. _Rigo_
    _Rigo_ Member
    San Antonio, TX
    Recommendation on which ones? Looking for 3". I'm not sure if it really matters which ones I get, because they vary in price online (Amazon/eBay)
    Thanks!
  2. Smugmetal
    Smugmetal Member
    Cleveland, OH
    78 Pickup
    Sounds like a good amount of people go with the cheaper universal blocks from chain stores. Some have issues, some don't.
    For what it's worth, I recently placed an order for blocks from Beefed Tacos. Much higher quality kit made specifically for our trucks. To me, the quality is worth the investment. Ultimately up to you though.
    http://stores.streetacos.com/
    _Rigo_ likes this.
  3. jetas
    Order from beefed or you can always look for "lift" blocks online those are usually pretty beefy
    _Rigo_ likes this.
  4. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    I haven't installed mine yet but I got my 3" blocks and ubolts as a kit off eBay -- all steel vs the alloy ones. I had a k5 blazer years ago that cracked an alloy block somehow, good thing it didn't fall out!
    _Rigo_ likes this.
  5. _Rigo_
    _Rigo_ Member
    San Antonio, TX
    I've looked into the beefed taco ones, they're just too pricey for me.. I'll look into those steel ones and lift. thanks, guys.
  6. _Rigo_
    _Rigo_ Member
    San Antonio, TX
    Oh, I forgot, balltech has drop blocks available, seems like they're a trusted brand from what I've seen on here?
  7. BeardNomad
    BeardNomad Newbie
    Idk about your gen but they also make lowering leaf springs for the rear of my 80
    _Rigo_ likes this.
  8. _Rigo_
    _Rigo_ Member
    San Antonio, TX
    78, I don't think I've come across that.. I'll look into that too
  9. Perkolator
    Placer County
    1975 Hilux
  10. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Blocks will be the cheap and easy way to go, drop leafs will be pricier and require new shocks that are shorter.
    I ran aluminum Belltech block for a couple years before I made the switch to drop springs.
  11. _Rigo_
    _Rigo_ Member
    San Antonio, TX
  12. _Rigo_
    _Rigo_ Member
    San Antonio, TX
    what made you switch from the blocks to the drop leafs? if i may ask
  13. Justin Danger
    Bay Area Peninsula
    axle wrap and wheel hop. Blocks are kinda a dirty way to go, just slappin in some spacers between the leaf and the axle. Drops leafs is like a stock setup, just de-arched to create a lower ride. It is much cleaner and reliable.
    That being said, I do plan on going lower, and have been looking at one of Beefed Taco's 1" lowering bolt to leaf blocks.
  14. jetas
    If youre just cruising in your truck you wont even notice any wheel hop or axle wrap.
    BeardNomad likes this.
  15. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Angled blocks are what to use,keeps the pinion angle correct.
    When I rode static dropped I ran 2'' angled blocks & 2'' dropped rear springs, the rear end was hitting the frame over bumps so I just moved ahead & installed the 8'' frame notch has bagging was in my plan!
    At the front I had installed Belltech dropped spindles has was needed for bagging.
    _Rigo_ likes this.
  16. _Rigo_
    _Rigo_ Member
    San Antonio, TX
    I'm looking at angle blocks right now, 2degree angle blocks? I've seen a few on eBay now
  17. motiusclyde
    motiusclyde Newbie
    for the tapered blocks, which way do they face?
  18. Perkolator
    Placer County
    1975 Hilux
    Typically for drop blocks, thin end toward the transmission to point pinion downward to maintain proper driveline angles, since you're now moving the axle upward.
    Peter T likes this.
