daily driver 1971 hilux
Discussion in 'Pre-1975 Build-Up/Project Threads' started by williyumz, Jul 4, 2012.
  1. williyumz
    williyumz Enthusiast
    hi everyone, just thought i'd share a little bit about my 71 truck
    bought it in stock form with lexus wheels and spacers, turned out that the motor was bad, but it came with one extra 8rc and one 18rc,
    without hesitation, i lowered the truck 3 inchs, took off the lexus wheels and went back to stock
    found out the exhaust was super gutted
    so i fabbed up a trd unit and made it a side exit
    i got the car ready within a week to go camping
    i was surprise the car made up the moutains some 30 miles off of georgetown, ca
    here is a beauty shot :)
    i was even able to make local runs pulling a trailer
    i'll probably be posting more as i go :) so far this truck has been super reliable
  2. 74Hiluxproject
    74Hiluxproject Enthusiast
    Olympia WA
    1974 Toyota Supra Truck
    clean truck bud, good work!
  3. ghettoyde
    ghettoyde Enthusiast
    Nampa Idaho
    Very cool! Looks to be in real good shape
  4. jeremyd
    jeremyd Newbie
    derby ks
    72 toyota hilux
    very clean truck!
  5. blueline54
    blueline54 Member
    1971 RN12
    I love that 3" drop. Adds a slightly aggressive look without losing any functionality. Care to share how you did that and so quickly?
  6. 22R88
    22R88 Veteran
    South Louisiana
    1988 Reg Cab Deluxe RN50
    Looks good, I prefer the Lexus rims Cool Ole Yota for sure !!!
  7. 74Hiluxproject
    Olympia WA
  8. kma
    kma Member
    Nice. Is that the factory color?
  9. kmghawaii
    kmghawaii Enthusiast
    maui, hawaii
    1969 Hilux
    sick. what TRD exhaust is that? model/specs?
  10. digital-i
    digital-i Member
    Hawaii
    1974 Hi-Lux
    Nice !!!!!
  11. brovender
    brovender Enthusiast
    Upstate SC
    1973 Hilux RN27
    So jealous! I wish I had the 1st gen!
  12. williyumz
    Thanks for the compliment guys,
    @blueline54, i dropped the front by cutting 1.25 coil, the rear has autozone 3" blocks, their u bolts are poop though, will get quality u bolts later.
    @kma, yes thats the original color of the car,
    @kmghawaii, the trd exhaust i used is from a pre 2000 camry, both tail pipe and muffler were cut up and rewelded for the side exit configuration.
  13. williyumz
    Small update, i had the stock air cleaner removed to clear a bigger brake master from a 90-02 style 4runner,(pedal feels much softer and brakes better).
    Also installed a cheap spectre air cleaner for now and a cheapo breather, now the car makes a cool hissing sound from the carb.
    Future mods maybe to install a summitracing radiator in replace of the 77 that i ghetto rigged. Or maybe I should just have the stock 71 original recored
  14. brovender
    Upstate SC
    1973 Hilux RN27
    my vote is the stock recored, unless you get one of those hella suave aluminum radiators.
  15. williyumz
    Some update
    Blow through subs!!! 1:1 ratio bandpass
    Box in
    Door panels using hardie panel, needs paint and armrest handle
    Needed security for my box so here is a $100 bed cover build with metal
    Frame functioning
    Hardie panel on ready for paint, still need hood shocks cause it's heavy as hell.
  16. AGUILAR3
    AGUILAR3 Veteran
    SoCal (626)
    Love the truck but IMO, you ruined a perfectly good truck with the blow-through :duh:
  17. williyumz
    Well this is just my toy truck, I went with blowthrough so I won't have to cut er open as much, I love music so what can I say haha, next I plan on making a removable wooden or metal cage so I can stack things on top of the bed, heck maybe even put my Yakima rack on :)
  18. blueline54
    blueline54 Member
    1971 RN12
    Hey Williyumz, did you have a hard time finding a breather that would fit on the valve cover? I kind of like that. I assume you just plugged the fitting on the intake manifold?
  19. williyumz
    @blueline54, I actually left the PVC to intank alone so it can circulate the blow by pressure, I eliminated the stock air cleaner so I had to run that wannabe air breather, it leaks small amount of oil mounted side like that, by the way it's a universal American v8 breather.
  20. CodyX36
    CodyX36 Enthusiast
    Seattle, WA
    '72 RN14
    Looks good! Did you stick with stock shocks after cutting the 1.25 coil off?
