crown vic sport mesh wheels
Discussion in 'Wheels/Tires' started by JOE_1985, Jan 6, 2010.
  1. 94Yota_05CBR1K
    94Yota_05CBR1K Veteran
    San Diego aka SD, Daygo. Cali
    94 YoTa Mini 2wd
    I hope they do fit because I just bought a set. i know they make them in 15's and 16's. I got the 16X7. I should be good right?
    BTW I couldn't find any Regals that come with mesh wheels.
  2. Comrade_Charlie
    Comrade_Charlie Veteran
    Rock Hill, SC. Charlotte, NC
    1973 Hilux
    Id say crown vic wheels are probably +23 or something close to that.
  3. 94Yota_05CBR1K
    94 YoTa Mini 2wd
    really? wow.. so therefore?
  4. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    I have a set of Mercury Maruder 18"s on mine. Fit great. Had to put spacers to move them out a bit. Believe the offset was +40
  5. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    check it out............. not sure on the offset but these are mounted and runnin 205/55/16 tires....... look great......... cant wait to see this thing dropped a couple more inches.....
    ill get better shots in the daytime.
    By alisn4x4 at 2011-02-02
  6. ttimpain
    ttimpain Newbie
    These look sick, I really wanded network and back a number of forums. 15x70 should tuck in your car like a year.
  7. topcop182
    topcop182 Addict
    Colorado Springs Colorado
    1993 single cab 2wd
    :confused:
  8. 94Yota_05CBR1K
    94 YoTa Mini 2wd
  9. yankeetaco72
    yankeetaco72 Veteran
    Escondido
    82 short /97 Tacoma
    Wow simply wow..
  10. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    X2 on that ^^^^^
  11. natedogestyle
    natedogestyle Newbie
    What size tires?
  12. SD YOTA
    205/55/16
    By alisn4x4 at 2011-02-12
    hows the truck runnin bro? :waytogo:
  13. topcop182
    topcop182 Addict
    1993 single cab 2wd
    What kind of drop is on that what truck?
  14. SD YOTA
    cranked torsions up front...... removed bumpstops.......
    3 inch blocks and 700lb bike drop in the back :lol:
    i think in order to end up at this height it will take around a 5-6 inch drop on each end from stock.
  15. 94Yota_05CBR1K
    94 YoTa Mini 2wd
    Lol... :lol:
  16. jblaust
    jblaust Veteran
    Miami, FL
    1994 Pickup Standard Cab Base 22RE Manual
    What size rims and offset were these?
  17. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    seen a set of these wheels on craigslist off a mercury marquis....the dish was the same silver as the face(painted).
    Do the lips need to be stripped and polished to get this look? or, do some of these wheels come bare aluminum already? any info would be helpful, thanks!!
  18. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    When i got mine off a crown vic, they were painted silver in the middle and raw aluminum lip(most likely cleared?).
  19. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    yeah, thats what most i have seen too. read online ppl stripping lips and polishing. and i assumed it was clear, not silver paint like these....hmmm. i wonder if these would be same, but strip paint and then polish? idk, if anybody else came across or seen anybody do this style. been looking for these wheels forever, finally find them and they are not quite the ones...arghh my luck lol
  20. AspireCycle
    AspireCycle Member
    Phoenix, AZ
    1978 Longbed 5 Speed
    Just so you guys know, there are three different "versions" of these 16" wheels....
    The Crown Victoria version has a double stepped lip, and a lower offset (more poke). The mesh "spokes" are made to look like they overlap, and the star pattern around the lugs in the middle has a straight solid border.
    There are two different Lincoln versions, from the Grand Marquis or Towncar, maybe the MKVII. One version (V1) has a single stepped lip, higher offset (less poke). The other version (V2) has a double stepped lip like the crown vic, and a lower offset (more poke). The mesh "spokes" are FLAT, they look more like ENKEI 92's, and the star pattern around the lugs in the middle has a jagged edge.
    I ended up getting the Lincoln version, two of each, so I can have a staggered set. On my '78, the rear hubs are tucked further under the bed, so both front and back will be flush with the fenders, and the rear wheels will have more lip. Good luck with your search!!
    PICS ATTACHED
