Ok so when I bought my 73 hilux it had a front disc brake swap already and what I was assuming to be the original master and booster. The pedal went all the way to the floor then the brakes would start slowing. So I replaced the master and booster with those out of a 81 toyota pickup (brand new). That then caused the pedal to be really hard and barely move, drove it to work the other day and the brake pedal got harder the usual and I smelled brakes, once I got home I figured it was a locked up caliper. I replaced the calipers today bled brakes drove it and I'm still having the same problem. I'm frustrated and stumped at this point anyone have any ideas? Brakes are hard and get harder as I drive, new master, booster, calipers and pads (out of a 81). It does NOT have a proportioning valve yet any ideas or suggestions any info would be appreciated
A vacuum leak at the booster would just cause it to stop boosting. It would make the pedal hard but that's because you would effectively have manual brakes. alwaysbroke, I'd check to make sure the slide pins are in good shape and well greased, it sounds like the brakes might be sticking.
The slide pins are brand new and I greased em before I put em in, I think they're sticking too, is there anything else that would cause that?
I read in a couple places that it could possibly be a co lapsed brake line(s) they look pretty bad so I'll try and get some and replace those and see if that helps. Anyone else hear of anything like this
Ok, I'm goin crazy tryin to figure this out, I just replaced the brake lines with new ones and still have the (I think it just the passenger, maybe both) Front caliper(s) locking up I need some help ASAP
Does it happen when you're turning? It might be a soft line binding up and causing pressure to build.
Ok I finally figured out the problem, does anyone know how to shorten the booster rod that goes to the master
anyone know if a 83 booster will work? I can probably get one for cheap with the MC. I already have the spindles, calipers and all that. What else would i need to pull from the donor?
I put in an 83 booster. I've yet to finish the setup so can't promise with 100% certainty it will work but I had to take the spacer out in order for everything to fit happily.
I don't have a pic, but I can take one tomorrow. Spacing was totally fine around it. Really no problems other than removing the spacer and making my own gasket.
Post up a pic if you can. Theres a 83 im getting the engine from and i might try to get the booster while im there
