Beefed taco bolt on c notch kit?
Discussion in 'Suspension/Chassis' started by vegas_yota, Jan 21, 2017.
  1. vegas_yota
    vegas_yota Member
    I had a question about the kit i was curious, do i gotta removed the bed to install his kit? Droped my truck somemore today and im bottoming out my rear end not excessive but when i hit dips or bumps. And in vegas thats prettt much every where lol
    LAYNLOW likes this.
  2. vegas_yota
    vegas_yota Member
    Heres some progress
    twizted1 likes this.
  3. LAYNLOW
    LAYNLOW Veteran
    Amherst,VA
    93 Toyota Pickup 2wd
    Id probably say yes to taking off the bed.mine does the same if the air is too low on my shocks. I have a bolt on cnotch kit but haven't installed it bc of the airshocks. And i have a 7" drop in the back.
  4. vegas_yota
    vegas_yota Member
    How does it ride with the air shocks i was debating if i just go that route for now while i decide on which notch kit i want beefed tacos kit is nice but kindof pricey, which notch kit did you get and from where
  5. LAYNLOW
    LAYNLOW Veteran
    Amherst,VA
    Rides good with the air shocks. Definitely useful when hauling stuff! I got my kit from ebay. Screen shot the wrong one but its the same. Still have mine sitting in the garage lol
  6. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    looking good out back. what all did you do? also, what size tire you running on those mesh wheels?
  7. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Just make sure you get good quality air shocks, my last truck had some (gabriel I believe) and they were junk, they would loose pressure in a matter of hours. I could pump them up at night, then go out in the morning and they would have lost their pressure.
  8. vegas_yota
    vegas_yota Member
    Cranked torsion down up front, 3 inch blocks out back and pulled middle leaf rides nice except for when i hit dips and the axles slaps the frame. They are actually crown victoria wheels polished lips wraped on 195 45 r16s
  9. vegas_yota
    vegas_yota Member
    So they dont bottom out with a little air in the shocks? Got any pics of your truck bro?
    LAYNLOW likes this.
  10. vegas_yota
    vegas_yota Member
    Thanks bro ill try out the monroes
  11. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    nice!! wheels look good...yeah around here they are called crwon vic mesh or meshies...in the back did you remove the bumpstops? because maybe you are hitting them and not the frame....
  12. vegas_yota
    vegas_yota Member
    Took bump stops off
  13. LAYNLOW
    LAYNLOW Veteran
    Amherst,VA
    If i hit a big dip or bump at decent speed it does but for the majority of the ride its good. I got some posted here in the gallery. I lost my okd phone that had all my pics. Havent taken any yet on this one
