If both engines are R series engines then yes. Only thing that will probably change is the location of the trans mount on the crossmember and maybe the driveshaft if the new trans is longer
This is the where the speedo hooks up on the 91 5 speed. Can I hook up a speedo cable in an 86 std cab 2wd ?
