I saw this new pickup with these 17x6.5 Honda Accord rim on the other day. The offset is 55. The bolt pattern is 5x4.5. What I was wondering is that anyone knew whether this will work or not, With spacers or not? Please help. If not ill find out and post back. Thanks
the bolt pattern is correct, i think..man i wish i still had that web page that had all the rim bolt patterns for lots of vehicles
you'll need spacers. If the rims are +25 or around there, you should be good. Anything more won't clear.
i'll sell you mine if you want them. 5x114.3 front: 25mm rear: 30mm bore is 60 i think. not totally sure.
I would like to see a second option if you don't mind. Does your spacers come with studs and the bolts? For the time being; How much for the two?
Please clarify what you mean there man because I run +45 and my clear beautifully, are you saying this style or, please clarify for everyone or retract
