22re swap to 2rz??help please
Discussion in 'Engine/Drivetrain' started by Playinwithtoys, Mar 13, 2016.
  1. Playinwithtoys
    Playinwithtoys Member
    Guam
    91 pickup
    Ok im getting sick of these other minis out here passing my ass on the highway. I have a 2rz sitting on the side in my garage with a w59 trans. The problem is,my dog chewed some of the wires on the 2rz and i am not much of a wire guy. My biggest question is, if i get a harness for the 2rz from the junkyard will it wire up to the 22re dash? I have a 97 or 98 2rz and my re is a 91 . Someone please help
  2. sojayota
    sojayota Enthusiast
    This thread has some good pics. It's a 4x4.
    http://www.pirate4x4.com/forum/toyota-truck-4runner/367844-2rz-swap-finshed.html
    Here's a quote from the thread
    "There is only a few wires to hook up. The motor i got was from a manual and i got everything from the same truck as a package deal. I think there was only like 5 wires to hook up for the computer. The rest of them is the alternator and starter. It was a little more difficult than my 5.0 swap but not that hard."
  3. Playinwithtoys
    Guam
    91 pickup
    Thanks man,im taking a look at the site right now .
    sojayota likes this.
  4. EvoLLove
    EvoLLove Member
    Hawaii-Alaska
    94 Toyota single cab
    I believe Lce makes motor mount conversations that are bolt on
  5. EvoLLove
    EvoLLove Member
    Hawaii-Alaska
    Keep me posted plan on doing the same
  6. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Check Pirate4x4 and MarlinCrawler forums for 2rz swap info. I'd love to have one someday.
  7. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    They just sell Chillkat mounts
  8. Playinwithtoys
    Guam
    91 pickup
    Thanks guys , i am currently stuck with my 22re as of right now so my rz will have to wait . I did get it in my car tho. I had to make my own mounts with dom tubing and pretty thick metal plates . I put poly bushings from leafsprings into the dom tubing to give it less vibration and stuff from the rock of the motor .i might order wiring harness from painless wiring ? If im not mistaken thats what its called . Then i will show some pics of my update .
  9. joeynational
    PHX,AZ
    91 2WD
    Periodically check my build thread. I just bought a 2rz to swap my 22re. I haven't got started on it yet but will soon.
  10. 22r
    22r Veteran
    Maui
    Which Ignition system does it run? Does it have a distributer, 2 coil packs or 4 coil packs? If its a distributer ignition 2rz you can always carb it!
  11. Playinwithtoys
    Guam
    91 pickup
    Its a coil pack but idk if two or 4. How could you tell . I dont know what car/truck it came off of but it was in my ae86 when i bought it . I have another 2rz that came out of an automatic 97 tacoma . Could i use that harness to my one in the car ?
