What's the best company out there guess you can say get more bang for your buck building these 22r engines I want a semi performance engine weber carbs ,cam etc my Yota finally laid down on me at 298xxx I need to rebuild it but I want the best I can get at good price and where I can get these parts. I'll have a build thread soon as I gather all my info and begin ordering parts thanks I need the help miss my truck,
First off decide what rpm range you are aiming for. If you want to see a solid pulling engine up to 7k then you need to buy parts accordingly. Engnbldr.com has a decent quality full rebuild kit at a great price. Start with a solid short block and buildall the power in the head. Some mild port work and gasket matching will go a long way. Oversized valves will certainly help as well. Depending on your cam choice ie rpm range either a good tri y or long tube 4 into 1 header will be required.
Thanks I'm looking to make this build right I just want good components so I'm not wasting my time and money I want it to be solid by all means
Hell yeah agreed with 22R. Raff can rev to 7k on his motor, and probably spent that much too, nah just playing. Swap a 20R head on it too, boost compression
Mild performance- rebuild it with 10:1's Webers, Mikunis, or a Holley (on aftermarket intake) A header and exhaust And a mild cam Then gear your truck and drive it. But for REAL power (like anything over 150 HP) plan on boosting it or get a different motor. No need to spend money on high dollar rods, crank, bearings, rings, clutch, headgaskets , IDK about headwork though.... I dropped almost a grand into my cyl head (48 and 40's) and a adjustable sprocket, and basically only went a tenth faster in the traps. (To its defence the carb didnt idle and it still has lousy ass gears, with an open diff and street tires) Soo do what you want. I like mine because you can hear it 3 blocks away fron intake growl, but in reality, its quick (and gives my mustang a good run for its money), but no means nasty. Hope it helps
I totally agree with Oly the 22r motor will cost a bunch of money to make it really fast. Better off doing a swap. 1jz, 7mgte, 2jz or even a 2rz or 3rz would be a better choice. Good luck on what you decide though.
id love to do a swap but money is kind of tight i wish i could drop a 1jz right in if i can find one one whats all needed for this swap like wiriing harness motor mounts transmission?
