Zing the frame
Discussion in 'Suspension/Chassis' started by spanks_4, May 30, 2011.
  1. spanks_4
    spanks_4 Enthusiast
    Denham Springs, Louisiana
    Has anyone done this before that can tell me what else has to be done? Like to make the fenders and everything line up and look right?
  2. n2bnlow
    n2bnlow Enthusiast
    San Diego
    94 Toyota 2WD
    I did do mine. Actually clipped the whole front frame with a new one.
    I used the search button on this site and found this.
    Here's a great tech write-up on the process.
    Z'ing the frame
    Measure 5 times, cut once.
    Other things to be aware of are the brake booster, clutch master, and you'll most likely have to tub the firewall. These things all depend on the year of the truck, size and offset of the front wheels, and whether or not you'll be body dropping it.:waytogo:
  3. spanks_4
    spanks_4 Enthusiast
    I was more concerned about how to realign all the front stuff after doing the Z.
  4. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    If you measure out how much you need to Z it then mark a line horizontally then another the
    amount you want to raise the front then tack it in. Measure again to make sure it's right then weld it up an gusset everything. Then drop your front frame horns. If all your measurements are
    the same then everything should align right. Also your motor will be raised the same amount incase you didn't know. What I explained in the beginning sounds better in my head than what I typed put haha
  5. Shadetree Mechanic
    Shadetree Mechanic Addict
    Emerald Triangle, CA
    That's the purpose of the legs welded onto the frame. If you level up the frame and put legs at all four corners of the front part to be cut off (the back part of the frame should also be positioned on legs so it says put), then you can just raise it up and stick some 1.5" tubing under it to block it up or whatever the desired amount of z is. I used Toyota screw jacks that came with my trucks to raise and adjust mine since they have a pretty precise action compared to hydraulic floor jacks, but really if you do it right with the blocks there shouldn't be much adjustment needed.
  6. spanks_4
    spanks_4 Enthusiast
    You all keep missing the question: If you move the front frame UP then the fenders and stuff are going to move UP also. Anyone have pictures or anything on how to realign fenders with the rest of the body?
  7. Shadetree Mechanic
    This is how I did mine:
    The front cross member under the core support gets cut loose also. The fender mounts don't move up.
  8. Twisted Minis
    Twisted Minis Addict
    Poor Cal
    1980 Toyota
    You cut the front frame horns off and move them down roughly the same amount that you Z the frame.
    Do we have a face palm smiley?
  9. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Ya your moving the core support down. Your raising the middle section lowering the front which means the core support is going back to stock. Hence the fenders being in stock location
  10. Litneon
    Cocoa, FL
    94 xtra cab
    Yes, you will have to make two cuts to the frame. One behind the front suspension and one in front of the steering linkage and box.
    And yes Seth we do have this.... :duh:
  11. spanks_4
    spanks_4 Enthusiast
    Well the process has never been fully explained and I don't want to screw my **** up!
  12. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    In the how to Z it explained it pretty goodi think. Everything should line up correctly IF your measurements are right if they're off then it won't line up properly
  13. n2bnlow
    n2bnlow Enthusiast
    San Diego
    94 Toyota 2WD
    You keep missing the answer. :rolleyes2:
  14. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    ^ agreed
  15. jetas
    Lol. Only thing being raised is the suspension and steering components. Fender mounting points wont be affected unless u dont Z the core support mounting locations the same as the Z by the firewall
  16. Litneon
    Cocoa, FL
    94 xtra cab
  17. Twisted Minis
    Poor Cal
    1980 Toyota
    This is one of those things that I think, if it doesn't click in your head pretty quick, you shouldn't do it.
  18. jetas
    Lol. Bagging a truck in general is one of those things. U cant just go at it all willy nilly
  19. Twisted Minis
    Poor Cal
    1980 Toyota
    This is true. But there are certain aspects that are more difficult than others, that I think the average guy should not be doing if he can't wrap his head around it. There is a reason I don't share a lot of pics when narrowing an axle, building or modifying spindles, Z'ing a frame, etc. 4-link design is another one of those things most people don't seem to understand, but its a lot less likely to kill you if you get that wrong.
  20. jetas
    Only thing wit 4 link designs for me is the instant center and squat. Which is the whole sh!t haha. Building tube arms is also something that i know i wouldnt be able to handle til i learn more about BJ angles and all that.
    Z'ing is simple enough. Things that need to be done AFTER the Z is what no one really anticipates
