well guys got pulled over today to find out my tail lights arent working. my brake lights work and m signal and reverse light works....but the thing that doesnt work is the normal running lights at night. i have LED tails. and i was wondering what to check for my tail lights? fuse? or should i just blow it up?...idk if this plays a factor but dash lights dont work either because of a connection...could that be it? the light dimmer isnt connected..
I would check the headlight switch. It seems its not allowing anything other than the headlights to operate. The blinkers and brake lights are independant of that switch. And whatever isn't connected should be fixed. You'll get it sorted out.
yeah i connected the dimmer but the dimmer doesnt work. so im tryna find a way to bypass that dimmer to allow power through..i have agut feeling that its the dimmer thing that has to do with the lights....but idk...so your saying check the connection on my steering column part?
My caddis did the samething everything worked except my run/interior lights check the fuse I. An see if the wires on the tails are touching an blowing the fuse
hmm i ****ed up my fuse box so i dnt have the diagram stuff....and my interior is being dumb..ugh...yeah ill check anykine fuses..lmao...and ill see..what did you find with your caddis? fuse?
this happened on my old 83. you definatly have a short some where. id start at the from and jut follow all your wires back to the fuse box. i know its going to be a pain but thats wat i had to do
i hate following wires...lmao...damn ill have to check that today and hopefully find out if its the damn switch thats ****in with me...ugh.
On my caddis I just had two wires touchin by the lights causing it to short out an blow the fuse. So if I were you I'd just check all the wires on the tails an wrap each one seperately with electrical tape. Change out the fuse an then u should be good. Cuz I noticed that wen I blew that fuse I had blinkers an brake lights just no interior lights or running lights. It'll be the fuse that says gauges or something
well i have a similar problem, my blinkers do not work, only one side works and it works at different speeds each time and dies. same happens when i use my hazzards
sounds like a short to me. had the same prob in my z71 it ended up being my pigtail for my trailer lights. it was touching my hitch i put some tape on it and havent had any proublems since
when i installed my cd player i touched wires and blew something, but all the fuses are fine. the cabin light doesnt work not, neither does the clock. ??
