So I picked up a set of Xrunner wheels that I am waiting to arrive. I know I have to adjust the center bore... 67.1 on older toyotas and 60.1 on newer ones. So they have to open up 7mm... The rims are 18x8 with 30mm offset. The tires are 255x45x18 I believe. Besides the center bore... how do you guys recon the wheels will fit? My suspension is all stock with 2wd fenders. Do you think they will rub in either direction? Do you think with 4wd fenders they will fill out the space nicely? Thanks for the input.
Just a long over due update. I finally got the rims bored and mounted today. The fit perfect! They don't rub on the extremes with one exception... If I crank it hard... and I mean really hard it will just barely rub the front inside corner... but it is very rare (maybe tight tight parking) that I would have to crank it like that. Other than that the center caps will not go on in the front. The cap of the bearings prevents it from setting in... I recon I need about 1/4" or 1/2" more of clearance. I was thinking either half inch wheel spacers or maybe I could flatten the bearing cap a little... Any other ideas? I will post pics of the truck/wheels/interior some time this week. Been so side tracked with other projects/lazy so that's my excuse for not doing so thus far!
PICTURES!!! PICTURES!!! PICTURES!!!! man someone kick this guy off the forum, he broke the LAW!!!! jkjk but seriously, WHERES THE PICS?????
You guys are tools! There have been picks up for a couple (maybe few) weeks now. Check my build thread. I am still guilty of not posting pics of my interior or engine... but I have had picks of the truck.
To make it easier... http://www.toyotaminis.com/forum/showthread.php?t=2703 General you even commented on the thread nublet.
j10nk what size tire do u have? i have same wheels but no tires! the reeson why i ask is because i dont want a big tire i want to go with a thiner tire.
255x45x18 They are the stock potenzas that came with the rims. With the combination of the tires being low profile and the rims being bigger... they require and extra inch or so of room give or take... (with these tires mounted they end up being on 1 in bigger diameter of the stock rim and tire that was on truck). Hope that helps.
. . . well all Im going to admit is that Im blond . . . Nice pictures man, great job keep up the good work . . .
