would nissan rims fit my 91 toyota
Discussion in 'Wheels/Tires' started by krazedprof, May 3, 2009.
  1. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    i have a chance to buy a set of 18's nice rims for 150 but the bolt pattern is the same but they came from a nissan 240sx im just trying to find out if they would fit thanks
  2. FOKAI
    FOKAI Veteran
    SD
    84 truck, 05 4Runner
    They should fit but you would have double check the center bore on the front wheels. If not run 1" billet wheel spacers. What is the offset of the wheels?
  3. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    yes. nissan 240's run a 114x5 wheel patterns. center bore will be your only concern but as FOKAI mentioned, wheel spacers will fix that issue. :waytogo:
