work wheels?
Discussion in 'Wheels/Tires' started by suzuki07, May 1, 2013.
  1. suzuki07
    suzuki07 Enthusiast
    baytown, tx
    92 isuzu , 92 yota, 07 suzuki
    Was wondering if they would fit my 92 Yota.
  2. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Yep.
  3. suzuki07
    suzuki07 Enthusiast
    baytown, tx
    Xs5875 hey am I going to need spacers or they will bolt on with no problem
    Also am I going to need fenders rolled. I ask because I was going to buy some
    Rotas grid wheels but I went to a shop and they called asked for 17x9 but only make them in
    Green and I wanted black. :-( so I found these :)
  4. estgang1991
    estgang1991 Enthusiast
    oklahoma city, oklahoma
    '89 hilux
    getcha a phone book!!! :waytogo:
  5. IronNam
    5 lug?
    Yes.
    After that, you just gotta figure the size and specs out.
  6. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    You'll want something in the 7" wide +35mm range. Diameter is up to you. And make sure the center hub hole is large enough. I think out trucks need 67mm. Correct me of im wrong.
  7. standardbyker88
    lynnwood, wa
    9" wide may work up front depending on your drop an how much offset it has. It could hit the control arm or tie rod linkage at full steering lock though.
  8. IronNam
    my 18x10's don't touch my control arm or tie rods at +22mm. It only brushes the strut rod, that's it, but barely.
  9. suzuki07
    suzuki07 Enthusiast
    baytown, tx
    am still not sure what wheels to get. I found the work wheels that caught my eyes but then I found this but don't know if they will fit . I want 17x9 have a good looking offset then I'll add a clean tire tucking drop. So thanks for any info.
  10. IronNam
    Those will fit fine.
    I have 4wd fenders on my truck and 10" width with +22mm offset will tuck tire and leave it flush. Minor fender rolling if anything.
  11. standardbyker88
    lynnwood, wa
    i forgot the 79-95 trucks have a lower I arm and strut rod, not an A arm like the 78 and older. And i also didnt think of the offset with an 18 vs 16, which is what i have most experiance with. getting 17s soon tho. finally stepping up to the big leagues haha. even though i keep seeing luxs on 18s and 20s. *cough cough burnz*
  12. IronNam
    The strut rod that goes from the LCA to the front is the only thing that it should rub at full lock, this is with a ball joint flip. That's also a 17" rim, so the diameter is smaller, so it might meet the strut arm a little earlier. I had 16's before, too.
    but aside from that, 17x9's +22 will be nothing.
    I fit something a little more extreme.
