i need help on figuring out this wiring i just need to know where all these go or if they are all ground wires
the one in the third pic is the positive cable. the second should be the negative. having trouble seeing the first wiring.
do i just ground the wires to the motor and body? and where do the power wires go besides the battery and starter
i just checked my 4x4. my cables have been replaced so they are a little different. the positive- the red end hooks to battery, the black boot hooks to starter, the steel end goes to the engine bay fuse box thing. the negative- on mine i have the battery end. the first little connector hooks up to the side panel near the engine bay fuse block, then hook to the motor, and thats it. i would imagine that maybe yours work as a chassis and engine ground.
well i figured out the starter wire but i can figure where the little eyelit wire with the boot goees from the power wire also i have a wire that comes from the injector area that has 3 wires into one like square eyelit the wires are brown is this a ground? i hate wiring
i appreciate all the help and i actually bought that water pipe piece on ebay for my radiator thanks for the help on that also
heres a few square eyelit positive post w/ small wire. (i've installed a ford relay, otherwise it would go straight to starter) neg post where the neg connects to the engine
that helps alot thanx so the other 3 off my battery ground wire must just ground to the body and chassis than thanks again
hmmmmm. not sure. i've checked my harness in that area and i can't find the whitish wires with the round terminal.
