wiring help
Discussion in 'Interior/Electronics' started by yota4life, Mar 20, 2014.
  1. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    I need to wire in a new digital oil pressure gauge. Im trying to wire it into the ignition so when I turn the key it turns the gauge on. And then I need to wire the light into the gauge cluster lights. Which wires are for the ignition and which are for the lights? I have a haynes manual but I suck at reading wiring schematics.
  2. 1lowSr5
    1lowSr5 Addict
    In the garage
    90' xtra cab Sr5, 2003 taco
    Get yourself a meter, will be way easier. Find out what connections turn on and off when the key is turned. You can use the remote wire for the amp/ radio to turn on the relay also. But def getting a meter would be helpful. Sorry I don't know the colors of wires I just pick the ones that have power...
  3. raylcc
    raylcc Addict
    Denver, CO
    I wouldn't use the remote wire for the radio as it will shut off your gauge when the radio is shut off. But 1low is right. it doesn't have to be any particular wire, just one that is powered when the ignition is turned on. Just use a test light and a buddy to turn the key on and off and either splice into the nearest wire that works or wire to the fuse box. There should be an unused port you can use.
  4. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Ok I dont wanna start another thread but what are the am1 and am2 fuses for exactly?
  5. 1lowSr5
    1lowSr5 Addict
    In the garage
    Copied from another forum...
    30 amp AM2 protects things after the ignition switch , ecu usually things to make the engine run
    40amp Am1 protects tail lights, heater (after other fuses) and other things like radio, cig lighter but usually only comes into affect while the engine is running (i.e alternator turning and key turned
    the aircon fuse 30A is in a separate box next to the fusebox under the hood
    The alternator fuse is a seperate fuse again 80A or 100A depending on the car and protects the alternator where as AM1 protects after the alternator
  6. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Ok cool thanks for the help man guess I have to keep those then. Trying to delete wiring I dont need
  7. 1lowSr5
    1lowSr5 Addict
    In the garage
    What are you deleting wires for? Doing a wire tuck?
  8. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Motor swap haha
