will they rub?
Discussion in 'Suspension/Chassis' started by 87yota4589, May 24, 2013.
  1. 87yota4589
    87yota4589 Member
    Memphis, TN
    87 Hilux
    ok I'm looking at doing a 4/4 drop on my 87. my question is will my stock tires rub the fenders? I've got 205/75/14 on it now. I'm planning on getting rims and tires for it though, so I don't really want to buy new tires for the 14s.
    2nd question. What tire size would work right with a 4/4 drop and 16" wheels? If I have to I guess I can just save up and buy the drop stuff and the wheels and tires at the same time, but that takes longer. And I want to drop this thing now! lol
    Thanks
    Andy
  2. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    you could easily run some 205/50 on the 16 inch wheels and be fine. depending on the offset of the wheels you get, you may need to roll the front fenders for when you turn the wheel lock to lock.
  3. Gatordrag
    Gatordrag Enthusiast
    Rayne La.
    1985 Toyota Xtra Cab
    I am pretty sure with a 4/4 you can run stock tires no problem!
  4. lowplz
    lowplz Member
    Hayward, CA
    87 longbed
    mine rubbed when i had 205/65/15 in the front, switching to a 55 = problem fixed
  5. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    I had an 8" drop with 225/50/16s up front on my 78. Only rubbed on hard corners. I did alot of inner fender hammering. On my 92, I was 4" up front and had 195/75/14s clear. You should be good with a 50 or 55 series on a 16. Anything taller just looks too tall I think. About a 25" tall tire is perfect on a lowered toyota.
  6. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    it will rub
  7. 87yota4589
    87yota4589 Member
    Memphis, TN
    87 Hilux
    well I had a unexpected development today. A friend of mine had a mustang he just put some rims on so I picked these up for $150:
    they have 245/45/17 tires on them. I put them up next to the truck and they don't seem much taller, but they are definitely wider. I will have to buy tires for them soon though, they are pretty worn out. what size should I go with a 17x8 rim and a 4/4 drop?
    Thanks for the responses so far!
  8. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    since you have them already, throw them on. then look at the way they sit from every angle and measure out about a 4 inch drop. you could run a 225 or 235 wide tire easily on there. the 225 would stretch a little and the 235 not so much. imho id run a 225 or 235 up front and keep the 245 out back. you may be able to actually run the 245 up front as well with a little fender rolling and/or trimming.
  9. 87yota4589
    87yota4589 Member
    Memphis, TN
    87 Hilux
    thanks man. I'm gonna try to throw them on tomorrow and see what it looks like. I'm thinking its gonna look dumb sitting at stock height but we'll see lol.
  10. 87yota4589
    87yota4589 Member
    Memphis, TN
    87 Hilux
    well theyre on
    doesn't look as bad as I thought it would at stock height. ordered my lowering parts too
  11. burquescraper
    burquescraper Member
    Charleston sc
    87 xcab 91 rx7 totaled:(
    watch the back shock leaf plates mine shaved grooves in the sidewall till i trimmed them on 245-50s but i have 5 in blocks
