will these wheels fit?
Discussion in 'Wheels/Tires' started by suzuki07, Jun 10, 2009.
  1. suzuki07
    suzuki07 Enthusiast
    baytown, tx
    92 isuzu , 92 yota, 07 suzuki
    wondering if these wheels fit my 92 yoda? rota p1 wheels 18x8 5x114.3 48mm offset:confused:
  2. FOKAI
    FOKAI Veteran
    SD
    84 truck, 05 4Runner
    Too high of an offset. Only way those wheels will work is with a spacer of 1". I am currently running 17X8 rims with a 50mm offset with 1.25" spacers.
  3. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    yea...... sounds real deep offset.... ((it'll sink into the well to far and rub either the caliper or frame when you turn))
    these trucks tend to fit a +40 to +45 offset best (depending on tire size and wheel dimension combo)
    MacRib is running 18x8 fronts with +35 offset on a 1/4" spacer. in the rear he runs 18x8.5 with +38 offset with a 1/4" spcer as well and he does not rub.... so you can go fairly shallow offset with wide wheel and still get away with it. he is running a 4/3 drop. ((check out Lil red a second chance) build in the 89-94 section.......
  4. suzuki07
    suzuki07 Enthusiast
    baytown, tx
    bros i just finished talking to one of friends, he has 5 xrunner wheels hes salein for 600, but i talked him down, and he said 400 for all 5, these wheels run for 195 a pice on ebay what yall think oh oh and will they fit my yota? he will also leave them in payments because we use to be in the same race team
  5. SD YOTA
    i say go for it!!!
    not sure the center bore will slide right in on these older hubs but using either a 1/4" spacer or larger should make em clear no sweat. :waytogo:
  6. suzuki07
    suzuki07 Enthusiast
    baytown, tx
    going to check them out hopfully today
