I have a stock 1988 2wd pickup that is box stock. Could someone tell me if these will fit without any modification? Whats your thoughts on if they would look good or not? Here are the specs: STL3670 Ford Victoria Crown, Mercury Grand Marquis Rim Steel #7W7Z1007C Make/Model/Year: Ford Crown Victoria 2006-2011 Mercury Grand Marquis 2006-2011 Product Specifications: Product ID: STL3670 Product: Wheel/Rim Material: Steel Style: 10 Hole Finish: Powder Coat Black Size: 17x7.5 Lugs: 5 Bolt Pattern: 4.5 Inch Indents: 7W731007CA, X40911 OE Part Number: 7W7Z1007C Thanks in advance!
Will there be any rubbing or scrubbing? What does the center bore need to be to fit properly? Thanks http://www.hubcaphaven.com/p/4299/s...rand-marquis-wheel-steel-black-7w7z1007c.html
I think its 67.1mm but i could be completely wrong. And with that tire size you might rub. Whats your overall goal? Because if you plan on lowering it youll need a smaller tire
Just want something a little different but didn't want to modify such a clean original truck. It doesn't have to be steelies. What would you recommend? Thanks
Jetas was referring to your tire size, not the actual wheels. I think those 17" steelies are sexy. Always wanted a set for myself.
