will newer 17 inch jeep wheels fit on 92 2wd? got pics of wheels in question.
Discussion in 'Off Topic' started by duckyaz, Mar 1, 2010.
  1. duckyaz
    duckyaz Veteran
    Pinetop, AZ
    if not, is it cause the center bore of the wheel is too small or? cause if that's the case, i can get that fixed. don't want the jeep center caps anyways. please please please help me out here cause these are almost exactly what i want and the owner of the tire shop is a family friend and will hook it up for 150 for the set.
  2. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    im not sure the offset of those but i know the bolt pattern is the same so they should work maybe with spacers not sure though
  3. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    I agree, they should fit. But the tire shop should be able to tell you if you need spacers or not.
  4. IronNam
    17x7inch i believe
    only possible issue you MAY have is rubbing in the back on the control arms
    I have a fellow 2wd trucker on TN and he has Jeep steelies from a liberty, fits well (other than the large tires it came with)
  5. jetas
    just go and mount them. Not hard at all.
  6. duckyaz
    duckyaz Veteran
    Pinetop, AZ
    true. i'm gonna go check em out this week. gonna be 550 altogether with the wheels and 215 55 17 tires if the wheels will work out
  7. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    and you plan to lower the truck on big giant tires like that? do a 215/45/17
  8. IronNam
    wheels you can get, tires you can replace.
  9. duckyaz
    duckyaz Veteran
    Pinetop, AZ
    i don't plan to lower it except maybe 2-3 inches in the back. gonna leave the front like it is. i'll have some pics up of the truck tomorrow(with smashed front end).
