Wheel studs
Discussion in 'Wheels/Tires' started by Predracer, Mar 17, 2009.
  1. Predracer
    Predracer Toyotaholic
    Conyers, GA
    Long bed 80 2rz turbo machine
    Alright guys I really need some longer wheel studs so I can put my new wheels on. So does anyone know where I can get some or if another year had longer studs that I could use?
  2. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    Should be able to get some at your local auto store. Just tel them the length, threap pitch, and diameter of the stud and they should be able to help you!
  3. Predracer
    Conyers, GA
    Alright. Someone wouldn't happen to know what all that is would they?
  4. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    Sry not off hand.
  5. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    I know thread is 12mm x 1.5
    What wheels are you trying to run? Perhaps you need the longer shanked lug nuts instead of a longer stud?
  6. Predracer
    Conyers, GA
    The wheels im using have a tappered hole in them for the lugs and even when I get a tappered lug nut I can only get 2 or 3 threads started so thats my problem.
  7. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I had to get 1/4" longer studs for my 88 2wd @ the front when I installed Wilwood rotors. Got them from S.P. Auto, a local auto shop.
    Part #DOR 610-265, $2.09 EA.
    Stock ones were 37mm long.
    A Napa store should be able to cross referance this part number,don't know the manufacture.:cool:
  8. Predracer
    Conyers, GA
    Thanks for the help guys, maybe I can find some now haha
  9. Predracer
    Conyers, GA
    Anyone know the knurl diameter?
  10. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    These are the measurements for the 1/4" longer stud
    Thread 12mm
    Thread length 32mm
    Thread pitch 1.5mm
    length from sit to end 40mm
    knurled area od 14.27mm
    made by Dorman /part # 610-265
    265
    w
    10.9 is stamped on the end
    Hope this helps!:cool:
  11. Predracer
    Conyers, GA
    Thank you sooo much!
  12. Predracer
    Conyers, GA
  13. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I think those are just stock replacements,not longer.
    Don't see any length measurement!:cool:
  14. Predracer
    Conyers, GA
    Ah! This is annoying lol It would be a whole lot easier if the stores around here weren't useless.
  15. Racersk
    Racersk Member
    Check for the older Land Cruisers, they are what the Old school (RWD) Corolla guys use when racing. Take out one of you exsisting studs, or pull one from a wrecked truck to verify if they will fit right (Knurl area-the threadpitch is right).
  16. macawilial
    macawilial Veteran
    Born and raised in San Diego
    Just throwing this out there...
    Is it possible that the center hole on the rim you are trying to put on is too small to fit over the center hub?
  17. Predracer
    Conyers, GA
    No it was the studs but i got a different set of rims. Those are just sitting in the garage now.
  18. Racersk
    Racersk Member
    It figures, I just found the site 2 days ago, rehashing old threads...
    BTW my steel 17x7 Chrysler steel wheels (300M) fit no problem with 7/16" spacers on stock studs, the alloy wheels I just picked up have a thicker mounting flange thus maxing out the stud length-so no spacers with the alloys... I need to get real spacers so I can fill my fender flares...
    Bad pic, but it current.
    Shawn K
    Covington, WA
  19. Toyo Trucker
    Toyo Trucker Addict
    Question??????
    Why can't you just get these????:shrug:
    *please see pix.
  20. nugget
    nugget Newbie
    OKC
    83 std cab short bed
    Hey...I'm putting longer studs on the front of my 83 and I just bought the studs for the 83 4x4 truck...The front studs at about 1/4" longer than the 2wd ones. I'm going to put them in on monday the 9th..I'll let you know if they work. The modle # is 610-264...
