A friend of mine has a set of wheels for sale cheap, they were on a lower'ed 98 lexus gs 300. The fronts are 20x8 and the rears are 20x10 with a little 4.5 lip. I dont know about the offset just yet. I'm just wondering if they will fit in the rear, I'm lowering the truck with 2'' spindle drop and 3'' drop in the rear. I hope you guys can help me out. thank you!
my 19x8s rubbed in the rear AND the front. the rear only on hard corners. and the front when i turned them full lock. they offset was +40
Mine are a 20x8.5 +40 I have pretty good clearance. You still have to have around a +40 to clear the bed so the diff of width goes towards the frame I feel if you got low enough to tuck the it would hit the frame. You could do spacers if you didny go low enough to tuck.
it would look good with that wide of a rear but im pretty sure i narrowed rear in which you might could just use older gen rear theyre narrower not sure if it would be enough and possibly have to build a back half of the frame that would be narrower... hope that makes sense
Well, you are talking 20's. I responded and then deleted a day or so ago when I realized that you had said 20's. The overall tire diameter is probably bigger than my 18's,(at 26") right? So any info I can tell you probably won't help much. When I was trying to fit my 9.5" wide rears, I went out and measured. That may be all you can do...
