Wheel Question...
Discussion in 'Wheels/Tires' started by Under Construction '93, Mar 7, 2010.
  1. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    I am about to order some 18'x8 TSW Vortex's 114.3 of course... My question is the wheels have a +20mm offset which is the same as the stock offset. I shouldn't run into any problems with rubbing should i? I'm pretty low in the front...Rubbing fenderwells which are getting cut out real soon. And am also running 4wd fenders. Any info is appreciated..Thanks
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    that all depends on what tire size you decide to run and how low you are exactly...... you may get some minor rub. considering im runnin a 16x7front on a +18 offset and a 205/50 series tire on it and 2wd fenders.... i rub slightly given im dropped up front around 8 inches if not more.
    if you are cutting out the fenderwells then i would not really be so concerned about it either..... especially if you run 4x4 fenders
  3. IronNam
    I believe the steelies that our trucks had, has +38mm offset, on the 6" wide wheel.
    +20 on a 8" wide wheel on our truck, MAY have about an inch closer to the steering arms and all.
