Wheel Guru's help plz.
Discussion in 'Wheels/Tires' started by El_Papitas, Jul 6, 2013.
  1. El_Papitas
    El_Papitas Newbie
    I have a question that might've been asked before but no luck finding info. I have a 92 2wd single cab short bed. And I want to order a set of diamond wheels. And I have no clue how or what to do as far as fitment goes no experience on that. I wanna run either 15x8s or 15x10s which would be better to get a slight poke but a nice fitment.
    Thanx in advance.
  2. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    15x8 zero offset will get you close to the fender and allow for room to lower it with the right tire 15x10 will work but stick out a little further if its a zero offset wheel and may come in contact with the fenders if you lower it to much ..think you will be satisfied with 8 wide wheels and a zero offset ..it's flush with fender . And it's possible to add spacers if you want it to stick out past the fender a hair
  3. TheLoLux
    TheLoLux Toyotaholic
    Simi Valley, CA
    **** run the 15x10 and put 4x4 fenders on the fornt. That's all you need to do.
  4. El_Papitas
    El_Papitas Newbie
    Thanx guys, I can run any offset but they ask me all these questions that I no clue what they so yea I think ill run 8s but will they fit flush in the rear?
  5. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    If there zero offset rims they will sit even with the fenders they won't be sunk into the fender well
  6. El_Papitas
    El_Papitas Newbie
    Ahh ok I see so if I want a slight poke will I have to get - or + off set?
  7. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    You'll want a negative offset some were in the 10 to 15 negative offset
  8. El_Papitas
    El_Papitas Newbie
    Thanx a lot!!
  9. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Between -20mm and 0mm seems to be the combo to poke them out. +20-40mm will tuck into the fenders.
  10. El_Papitas
    El_Papitas Newbie
    So get 15x8 20 offset for rear? And maybe run 15x8 0 offset for the front?
  11. El_Papitas
    El_Papitas Newbie
  12. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    If you want them to be flush with the body a zero offset would be my choice it's close and looks flush and if your lowered a little front camber keeps them off the fenders . So rubbing and cutting tires is reduced
