Whats wrong with my breaks?
Discussion in 'Wheels/Tires' started by Bronga, Apr 13, 2011.
  1. Bronga
    Bronga Member
    Anchorage, Alaska
    93 single cab base 22re
    when i brake i get a bad pedal pulsation and the truck pretty much shakes.
    i replaced the rotors and pads but they still pulsate...
    also i have a bit of wheel slop/play since i put on my 225's (about 3 inches and makes it hard to control the truck at faster speeds)
    i used to get a "speed wobble" at about 60mph but after i got my tires balanced i dont get it until like 70mph
    i feel like all these things are related but im really dont know
    what do you guys think is wrong?
  2. IronNam
    do you have a basic idea which end it is coming from?
  3. mightymouse
    mightymouse Enthusiast
    st. louis
    1990 4x4,1991 2wd, 1984 sr5 4x4
    sounds like you could have a few problems here but i would first say it's a sticky caliper so make darn sure they both work, and work like they should not good enough. The check the rear cylinders for working order. After that bleed the system from passenger rear, driver rear, passenger front, driver front. If all of this checks out first put the front end up on jack stands and spin the tires looking for anything out of the ordinary like wheel wobble, loose bearings and such. Report after that with your findings and questions.
  4. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    You bleed from the far point to closest to the master.
    Drivers rear,passenger rear,passenger front ,drivers front.
    Put the bleed hose into a bottle with some brake fluid in it so you can see the bubbles & no air can return.
    Also check all your steering components!:cool:
  5. Bronga
    Bronga Member
    Anchorage, Alaska
    it feels like it is coming from both sides equally..
    what will bleeding the brakes do?
  6. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    did you check the rear? I had a leaking wheel cylinder that was sticking..Had the shake at highway speed, replaced the cylinder and all is well
  7. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    replace your front end parts like center drag link, idler arm, pitman arm, tie rods, and ball joints. 100 bucks says its a combination of those parts.
  8. Bronga
    Bronga Member
    Anchorage, Alaska
    sounds like an expensive bitch..
    we'll start with bleeding them.
  9. Bronga
    Bronga Member
    Anchorage, Alaska
    so the brake shaking seemed to go away when i got my new rims.
    but the wheel and truck now shakes at 45-50mph then goes away and comes back at about 70mph.. what could cause this?
    also i have about 3 inches of wheel slop/play and the wheels pull me from side to side freely as they hit ruts (its kinda scary) the truck seems to go where it wants to and is kind of hard to control.
    i have no power steering and possibly my steering box is bad? the wheel play seems to be coming from it but idk
  10. gilpet79
    gilpet79 Enthusiast
    MD
    94 2wd
    the truck pulling on you when you hit "ruts" is from having wide tires on the narrow frame and the curvature of the road aka the "crown", You should not have that much play in you steering linkage, especially since it doesnt have power steering. The next thing I would do is what CIN said start replacing linkage parts. Start with the tie rods, (those seem to go first) after that I would go to the idler arm (coming off the steering box) and just for fun why not put a steering stabilizer on it (what I plan to do to keep it from pulling) it will help take play out of the linkage and stiffen it up
    MY .02
    p.s. I work at a goodyear and see this one too many times
  11. gilpet79
    gilpet79 Enthusiast
    MD
    94 2wd
    btw check you ball joints and wheel bearings
    jack the front wheels up and shake side to side and up and down on the wheel
    side to side can be tie rods or wheel bearings
    up and down is usually ball joints
    and you may have to use some force up and down to get the balls to "shift"
  12. mightymouse
    st. louis
    Sounds as though you want to ask for advise and not follow it. Now properly check your brakes and front end and diagnose the problem. Have you bled the brakes? have you jacked up the front end and checked for play? aside from putting new rims on your truck what have you done to take care of this aside from posting on a forum? If your rims were warped before and the tires were out of alignment and unbalanced the rotors that you put on are most likely warped again as well. So to give you some proper direction start with an alignment, replace your rotors and pads again as i'll bet they are ruined. While doing so go ahead and jack up the front end and check for worn parts. You need to actually fix the problem and be able to diagnose it instead of throwing parts at it expecting it to change. New rims is not fixing the problem and of course that's going to change it as the most likely unbalanced tires you had before are now some what balanced via new rims. After you start actually fixing the truck instead of throwing parts at it come back with what you have accomplished and hash out the new problems. (if this sounds harsh it probably is and sorry for the harshness but i might be spending too much time on prate4x4) god luck and hope this sent you in the right direction.
  13. Dux_Trucks
    Dux_Trucks Enthusiast
    campbell CA
    1988 hi-lux std cab 2wd 5spd short bed
    :applause::applause::applause::applause:
