What wheels are these? Mustang? Size..
Discussion in 'Wheels/Tires' started by Heikki-B, Apr 19, 2017.
  1. Heikki-B
    Heikki-B Newbie
  2. jetas
    ZR SC wheels
  3. Heikki-B
    Heikki-B Newbie
    But is it possible to make that size fit? Without big mods.. some people say that 16x7 is a tight fit, some have no problems, Im confused
  4. jetas
    Offset plays a big role. Plus there is a possibility that the tires rub but some people dont care and you cant see everything from that pic
  5. yotarip
    yotarip Veteran
    I've run 16x9 - 0 offset on my 87 and the front fenders needed a roll, plastic liner removal and simple pull by hand to clear. The rear jap bed needed a serious pull.
    The truck in the picture is running 17x9 +24 like you said and they prob clear with no fender mods. You ban also dial in some negative camber in the front easily. The american bed will clear 10" wide wheels with 20 or 25 mm offsets. You can't go much higher in offset with a 10" wide wheel because the rim will hit the frame. A 40 or higher offset with 10" wide wheel would not even allow me to mount the rim on the axle. The inside lip of the rim will hit the frame.
    jetas likes this.
  6. Heikki-B
    Heikki-B Newbie
    Amen to that. Thank you for your answer. That was some really good info. :)
