What should I do?
Discussion in 'Suspension/Chassis' started by planemos, Jul 18, 2011.
  1. planemos
    planemos Toyotaholic
    British Columbia
    Hey I have been driving my truck around for a while now since I finished bagging it. But if I air it up and walk away, then come back later, the passenger side bags lose air. If I leave it overnight they lose all the air. I figured out it is leaking out of my 2 valves for airing down/out on that side. It's leaking right out of the oulet port! WTF eh:shrug:
    What do you guys think I should do about this. I put some threaded caps in there and it holds air all night now. Is it possible this could be my fault or are they defective?
  2. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    take apart the valve and clean the rubber part, its 4 screws. you constantly have to clean em cause water n junk gets stuck in the valves. congrats on the new install
  3. Litneon
    Cocoa, FL
    94 xtra cab
    Yeah, it's probably just dirt. I've had an occasional slow leak on my front passenger corner for over a year now. Doesn't leak every time, I'm just too lazy to chase it down.
  4. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Ya I got leaks too. My tank was brand new but has a pin hole in one of the welds on the bungs and my front leaks from the valves. I know where there at but to lazy to fix
  5. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Same story here man. I got all new fittings, line, bags but they still leak and its my valves which are probably 3 years old, like everyone else said take em apart and clean them.
    HOWEVER if the valves, tank, lines are new and you've been driving around in dry weather Im gonna have to go with defective or overtightened and you messed up the threads cause that would cause a leak if your using cheaper fittings.
  6. planemos
    British Columbia
    Alright thanks. I'll try and clean the diaghragm. It's completely possible that dirt got in there because they are pointing straight down at the ground. If this works I might put a 90 degree fitting on there to prevent dirt going in there. I remember once I was airing down in the dirt and when I drove off the patch of dirt there was dirt all under my truck and some holes in the dirt where the air exited. Thanks again sounds like that's what it is.
