what is this cap on the valve cover for?
Discussion in 'Engine/Drivetrain' started by not forgotten, Mar 3, 2011.
  1. not forgotten
    not forgotten Addict
    Washington
    82 SR5 L/B
    I was wondering what this cap on the back of the valve cover is for? My black valve cover from LC does have it.
    Does someone have a spare stock valve cover they can look at?
    Is it capped off on the inside?
    It is stuck on there, tried plyers and no budge, think its ugly
    If I take it off, and not capped off underneath I assume oil will shoot out the top, don't want that.
    Any help would be great.
  2. topcop182
    topcop182 Addict
    Colorado Springs Colorado
    1993 single cab 2wd
    I just looked at my spare, I am not sure what it is for, but its a bolt hole of some kind that does not go all the way through the cap. For that matter none of the bolts do so dont worry about oil shooting out. There is a plate on the underside of the VC that is tacked in to prevent just that. Good luck with the rest
  3. Nook
    Nook Addict
    oregon
    That cap, originally was part of the air cleaner mount, its not a cap but a rubber isolator that screws into the valve cover and the top which is broken off had a threaded stud that the air filter bolted down on.
    The hole is a blind hole and won't leak oil out if its removed.
  4. not forgotten
    Washington
    82 SR5 L/B
    So if I put some muscle to it and turned it lefty loosey it should unthread and come off?
    Thanks for the replies
  5. mikes87yota
    mikes87yota Enthusiast
    Tacoma Washington
    1983 2WD SR5 "Mojave Edition"
    Ya it will come off i did it to mine the other day
  6. jackash002
    jackash002 Enthusiast
    NE FL
    1982 2wd p/u, 1983 toyota trailblazer, 1982 toyota truggy (next, just a cab/frame now)
    or break, then it fills it's own hole. :cool:
  7. 22R_All_Motor!
    22R_All_Motor! Addict
    Houstone
    84 pickup
    well i thought for a while it was like a mount for the throttle linkage...
  8. lucky_brew
    lucky_brew Member
    i pulled mine off last night. its just a rubber bushing where the factory air cleaner mounts.
  9. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Yup. Extra mounting points. I cut mine off, and JB welded an alum plate inside the hole. The other few grind off smooth.
