what hubs fit the spindles?
Discussion in 'Suspension/Chassis' started by celica-fiend, May 8, 2010.
  1. celica-fiend
    celica-fiend Member
    Victoria, BC, Canada
    73 Hilux Longbox
    Hi all..
    I picked up a set of spindles from an '82 to swap onto my '73 to get disc brakes.. finally pulled them apart after having them a few weeks and found the inner bearing race is spinning in the hub.. so the hubs probably done.. anyone know what years of hubs will fit onto an '82 spindle?
    thanks,
    Brett
  2. Dogfather
    Dogfather Veteran
    Rochester, Washington
    1976 Toyota hilux & 77 Toyota Pickup
    I am no expert but my 76 has disc brakes in front
  3. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    75-83 has the same spindle/hub/brake assembley. parts, or entire setup, from any can be used to convert the 74 and back trucks to front disc. the 79-83 needs to be flipped side to side so the steering arm is pointing back. coil frame trucks had rear steering. torsion frame trucks had front steering.
  4. celica-fiend
    celica-fiend Member
    73 Hilux Longbox
    Alright cool.. buddy who's a factory tech is going to help me have a look at the race monday after work and see if we can salvage the hub.. otherwise I'll go try and find another parts truck to pull one side off of..
    cheers,
    Brett
