Weber-to-20R one-piece adaptor
Discussion in 'Engine/Drivetrain' started by MrDinkleman, Jul 28, 2023.
  1. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    This question seems to pop up regularly. I had to pull out my yet-to-be-installed kit for another reason so I thought would take a couple pics.
    The Redline (no affiliation) smog-legal Weber kit, K8747, comes with a one-piece adapter. I don't understand why they don't use this adapter for all their 20R kits. I think you can buy it separately. 20230728_182223.jpg
    Hope this info is of use.
  2. MrDinkleman
    MrDinkleman Addict
    SoCal
    If you can't find the Redline one-piece adapter, Transdapt (no affiliation) sells a one-piece raised adapter. 20230728_182551.jpg
  3. fred heath
    fred heath Addict
    Raleigh, NC
    Most of the Weber 32/36 sold on the secondary market are “Grey Market” carbs. They’re Weber clones. Redline is the official Weber Carb.
    Grey market carbs can be had for about $250 vs $350-400 for the redline. The two piece adapters were just poor engineering. Other than that there really is no difference in performance.
  4. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    The one piece can help against heat soak and more importantly sealing. Anyone woundering. To add to the picking out a carb they do come setup from redline. So you want to make sure you get one that is for your motor. So if you're looking to buy local and already buying the one piece don't just think because it's a 32/36 it will work well.
  5. sirdeuce
    sirdeuce Enthusiast
    '86 4Runner and '89 2WD
    A bit late on this one, but just for giggles I'll bring one I did up. I Okie-rigged my first weber by drilling and tapping the manifold, really ugly, but it worked. Second mod attempt was milling the manifold and welding in a plate to match. Both got the job done, but were really a waste of time.
    Your best bet, not bang for the buck, is an aftermarket manifold. Offenhauser and Cannon made good pieces. One of those companies (offenhauser I think) made one with a split level runner that isolated the primary and secondary carb barrels all the way to the head. That split mani was great for driveability, Heloed with torque and mileage, but performed about the same as the stock maifold. The best, in my opinion, was the offenhauser open runner.
    LC Engineering had a line on the Cannon manis. Better than adapters in any case.
    You can still find these manifolds in minitruck events swap meets.
