weber carbs
Discussion in 'Engine/Drivetrain' started by ToxicToyz, Feb 20, 2011.
  1. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    Anyone know the difference between the 32/36 and the 34/34 weber??What kinds of power gains and gas mileage could i get from each one??
  2. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Both are kinda small carbs.
    Ive put lots of 38/38s on yodas back in Colorado and they really like them.
    The gas mileage wont nearly be as bad as you think. Mid-hi 20s if you drive it nice.
    The 32/36 is a progressive carb. Meaning that one barrel is used for cruise, and the other opens with more throttle.
    the 34/34 and 38/38 have both barrels gear driven together. Called syncronous.
    The power gains will be nice with any of them. The stock carb BLOWS!!!
    I literally bolted on 30+hp with my holley over the stocker.
    But if I you, 38/38 it! :waytogo:
  3. JOE_1985
    JOE_1985 Veteran
    87 custom
    the 34/34 is progressive i had one on my other truck
    the new 36/36 is syncronized and as well as the 38/38
    the 34/34 has equal barrels so you can zip around quicker with the primary than u would with the 32/36
    overall they will have the same WOT performace
  4. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    so the gas mileage would be the same with the 32/36 and 34/34? Also if the secondary is smaller on the 34/34 then it will have a little less pull then the 32/36 when you stomp it but it will have more pull when you are cruising?
  5. JOE_1985
    JOE_1985 Veteran
    87 custom
    in the end id be round about the same, the cfm is the same and the barrels are pretty much the same if u do the numbers
    u may want to try the 36/36 its supposed to be syncronized but get better gas milage than the 38 but better performace than the 32/36
  6. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    so just to make sure Ill still get better gas mileage with the 34/34 weber compareed to the stock carb?
  7. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    how much should a 38/38 weber cost if its old and needs to be rebuilt and retuned to my truck
  8. 22r
    22r Veteran
    Maui
    the 32/36 with all stock internals and maybe just a header and exhaust the 32/36 is good, but like the 38/38 you gonna eat gas and gas aint cheap in hawaii. plus those damn webers love to run rich anyways so i would just run the 32/36 esp in our climate.
  9. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    If you have a built motor it will work just fine.
