weber carb which one should i get
Discussion in 'Engine/Drivetrain' started by codybourgeois88, Jun 6, 2010.
  1. codybourgeois88
    codybourgeois88 Newbie
    filer idaho
    1988 toyota pick up
    sorry im sure there are already threads on this but could not find it so which weber should i get where should i look to get one
  2. JOE_1985
    JOE_1985 Veteran
    87 custom
    if u want economy, a 34/34 which is really a solex i had one on my last truck it was alot better over the stock carb,
    32/36 would be the best all around
    38/38 syncronized if your going to be racing or just like wasting gas
    im curious about that 36/36 they came out with but its only availible for manual transmissions only so i probally wont get one. and i got a 32/36 off of craigslist for 50 bux
    you can go to webers site, ebay or it may be cheaper to go craigslist, get one and rebuild it if its been sitting
  3. 77yoter
    77yoter Veteran
    seattle
    77 sr5 shortbed, 81 shortbed, 90 4x4
    for a stock motor the 32/36 is the way to go even if your motor has some upgrades you can still use the 32/36 with some rejetting
  4. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Exactly. Stock or mild setup, run a 32/36. They are plentiful used if you wanna take it apart and clean things. And rejet it if it was on some other type of motor. If you plan to do a high compression, big cam, fire breather...the 32/36 will hold back its potential a bit. Thats where the 38/38 would really shine. Of course theres always side drafts, but I'm a fan of downdraft carbs.
    Basically the 32/36 has two ports. A big and a little. The little one is always being used, but the larger side doesn't open until about half throttle. The 38/38 has two larger sized ports that open equal amounts. So it flows more air/fuel overall, but also provides more at lower throttle situations that the 32/36 doesn't. People have gotten great mileage improvements from the progressive one. I have one, but for my motor's current build its not enough. Even with it being rejetted.
  5. codybourgeois88
    filer idaho
    1988 toyota pick up
    so i got a question i was wondering if i want to build my truck where should i start also my engine has 260000 miles should i rebuild it or i know when i had my 3tc corolla i was going to get a race built create motor can you get the 22r the same and where
