Ok heres the deal. Gunna have some stuff for sale.. The weber carb. I DO NOT KNOW WHAT SIZE IT IS! It does work though ! has electric choke and is virtually new ! comes with air cleaner and all. best offer has it. no low balls please. $10 shipping TRD STAGE 2 CAM. Im going to start this one at $150obo I know you can get cams cheaper but this is a TRD cam, they no longer make these. $10 shipping. A race clutch for sale, it has maybe 3k miles. the pressure plate is purple which makes me believe that this is a Zoom clutch but I dont know. best offer on this as well. $10 shipping. I have 2- 22r motors complete. I will part them out for the right price on the right parts. Both have bad cranks and I think 2 total rods are bad. I have 1 good crank for sale though. 1 motor has a brand new oil,water pump, timing cover, and timing chain. Best offer on all of these. shipping is going to be actual cost on bigger items... I will try to use my friends 75% fedex discount but no promises. last I have a early 22r head.. It is a 22r head with the lower compression similar to the turbo head. best offer 25 for shipping.
cam is used, I personally only put maybe 2,000 miles on it like most things on my truck specs are in the link I provided, just search for trd stage 2.
Any pics of the Weber? I'm looking for one. At very least I can tell you what you have, might get you more money if you know.
bad cranks... as in turned main bearings... and on both or is both of the bad rods on the same engine?
where are you located at? i keep thinking your in fl, if so i may want to come see it and pick up some other parts as well. was the "good" crank turned ? who makes the water and oil pump?
hmm i may havta skip on the crank since i have a few laying around that just need polishing. who makes the water and oil pump was the weber bolted up to a 22r before im interested just trying to get some more info im up in jacksonville btw
not sure who makes the pumps, got em online. weber was bolted to a 22r before mine and then mine both for very short times
its like a 2 inch high adapter and it is on piece with a rubber thing under it. B.Y.E. said it was the good one. the adapter says tb on it i think
hawaiin, yes i do. 813-833-3120. joe, thanks for the offer but i paid more then that a few months back and only ran the motor for 30 minutes.
