weber cams
Discussion in 'Engine/Drivetrain' started by joeyota653, Jul 22, 2010.
  1. joeyota653
    joeyota653 Enthusiast
    anyone tried these out??
    planning on getting a 292 but just want to know all the specs!
    and if theyre good cams!
  2. Nook
    Nook Addict
    oregon
    Sure its a Weber cam and not a Web cam? Web cams are good sticks, thats who LCE has make theirs, 292 is pretty healthy for an unmodified or lightly modded engine, specs for the 292 below--------
    Toyota 20 / 22 R SOHC 8v
    Part #:
    45-122
    Grind:
    172
    Intake
    Exhaust
    Valve Lash (Inch):
    .008
    .012
    Valve Lift (Inch):
    0.515
    0.515
    Valve Lift (mm):
    13.08
    13.08
    Advertised Duration:
    292°
    292°
    Duration @ 0.050":
    268°
    268°
    Lobe Center:
    104°
    104°
    Intake
    Opens
    30°
    Before
    TDC
    Exhaust
    Opens
    58°
    Before
    BDC
    Intake
    Closes
    58°
    After
    BDC
    Exhaust
    Closes
    30°
    After
    TDC
    Valve Timing Is Checked With Zero Valve Lash
    @ 0.050 Inches Of Valve Lift.
    Erwin Merida likes this.
  3. joeyota653
    its a weber...
    this discussion went on at dragguam.com, and some peeps said that weber did indeed make cams!
    im just wondering if they are any good??
    swapping my rc for it!!
    just wanna make sure theyre not duds...
  4. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    give em a shot..if its a dud its not like they are hard to swap back..
  5. joeyota653
    true true..
    just for safety precautions imma bring a stock stick just in case things smell fishy!!
    if all goes well with the swap, ill take some flicks!
    might get an 88 too that needs a shatload of work!
    just gotta ax my uncle about it!
    n ill be posting my build because i KNOW im going to need advice on bodywork and motor tuning!!
    thanks for the replies guys!
  6. joeyota653
    burn deal!
    damn the guy sold it already!!
    but he said hes getting another 1 and hes going to let me know when he gets it!
    kind of a good thing, cuz i want something around the 300 range..
    any good options??
    i really want to grab a TRD stage 3!
  7. IronNam
    Wish it works with the factory EFI with slight tuning....
    Oh well, megasquirt or ditch the 22re :D
  8. joeyota653
    yeah.. i dont know much on megasquirt, but would love to try something different in my truck!
    this would work too, right?
  9. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Im gunna say it, but a 292 on what kind of engine?
    Mines a 280* Comp. I luvs it.
    Ive heard and ridden in B.Y.E.s 310* (IIRC)
    There not for stock engines. :lol: Hint hint.
    Ive heard of weber cams for A/C volkswagens, they have a good rep. :waytogo:
  10. joeyota653
    im building a 22r motor.. aftermarket valvetrain, custom intake, ported head, stock bottom end..if needed i will notch the pistons..
  11. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    Yea 310* is not recommended for stock engines, just something I wanted to test out for myself...
    The 280* comp is your best all around cam choice and is proven!
    Lots of variables when choosing cams... Power band output, gear ratio, transmission, driving habits, ability to tune, carburation, etc, all play in it's part...
  12. joeyota653
    yeah i realize that..
    what do you mean by stock??
    top end or bottom end??
    i plan on modifying the head to the best of my abilities..
    bottom end might get balanced, but other than that, it will be stock internals..
    would this be a problem for 300*+ cams?
  13. B.Y.E.
    B.Y.E. Toyotaholic
    1982 2wd Hilux
    Topend... A good quality set of dual springs will make the most out of whatever cam you choose.
  14. Raffaelli
    Houston
    82 Longbed 2WD
    Stock bottom ends are as tough as railroad spikes. If you can get the 22R head to flow enough air, a 300* cam wouldnt be a problem. But you would lose a little of that low rpm drivability...
    And dont forget about valve/piston touching. Nothing a little grinder cant fix. :lol:
    What carb(s)/intake you want to run?
  15. joeyota653
    thanks for all the help guys!
    a 300+ cam would hurt drivability??
    how badly exactly??
    im planning on running a custom twin throttle body EFI.
    havent seen one on these types so trying something different:cool:
  16. Raffaelli
    Houston
    82 Longbed 2WD
    :lol: Second or third guy on my fuel injected sidedraft idea....
    I hope im the one to finish one first.
    My cam doesnt really get "in the groove" till about 3-3500, then its bat out of hell to redline. :evil: But that can be a combination of things such as a little 4 banger, avarage gearing, and maybe a little too much carb. :waytogo:
  17. joeyota653
    haha hey i didnt steal this idea from you tho!
    i had a thread called dual carb..
    but you were prolly the first to think it up!
    youll prolly beat me to it too, due to a lack of funding on my side..
