was hoping to have it fixed
Discussion in 'Engine/Drivetrain' started by dirty, May 6, 2009.
  1. dirty
    dirty Member
    garner NC
    i was hoping that i wouldnt have to ask yall, thinking i might have it fixed but no. my truck runs like a farmall tractor. im not sure what it is. i got the truck running this way but thought it was gonna be an easy fix well it probably would be if i knew what the problem is. at first i thought it was the tps out of wack. it was missing the set screw. did some checking against a known good tps and it all checks out good. thought the egr might be clogged. cleaned it out didnt change anything. i replaced it today and still no change(was hoping that this would be the fix to my problem:brickknock:). replaced the plugs with some autolites no change. gonna change to some ngk plugs prob this evening but it probably wont change anything either. ive ran 2 bottle of seafoam thru it and it cleaned alot of crap out there. looked like a nice healthy burnout with all the white smoke. ran good for a little bit afterwards but once that wore off it went back to farmall status. im at a loss as far as what it could be. a good friend of mine and toyota nut isnt sure what it could be either.
    any ideas that yall might have would be greatly appreciated.
    im dying to be driving this everyday and now im kinda limited to small store trips:cry:
  2. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    Take apart your MAF (Mass Air Flow Sensor) so that the little wires that the air flows past are exposed. Got to your local auto shop and buy a can of Sensor Clean.... or somthing similar. Spray the crap out of the wire to make sure they look shiny. Any dirt, or oil that can collect on the wire will be sure to give you running issues. Clean it all up, then put it back in. Should help.
  3. dirty
    dirty Member
    garner NC
    wheres the maf at on?
    im not really familar to yota motors
  4. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    Ohhhh actually...... now that i think of it.. toyota used a different style of MAF called a trap door. Right after your air filter there is a box. Take that apart and you can look inside to see a door. Push on that with your fingers. If it moves freely all is ok. But if it feels tight or sticky even the slightest bit, that will affect runability.
  5. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    How old are the plug wires, cap & rotor button?? After you check the MAF sensor check those too.
  6. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    hmm.... what did your old plugs look like? brown? black? cruddy?
    i had a similar issue with my 4Runner after a rebuild and turned out the truck was running way too lean.....
  7. trap
    trap Addict
    orange county ca
    92 pickup
    adjust your valves
  8. dirty
    dirty Member
    garner NC
    ill check the maf and see whats up probably tomorrow night.
    the plug wires are new, the plugs werent that bad. one was black and the others just looked like they were in it to long. rotor button and cap are new as well
  9. SD YOTA
    one was black? if you let it sit there and idle, do you get a slightly richer smell (than usual) out of the exhaust? you might have a bad or leaky injector spewing too much fuel in at idle....... just something to check out. its odd you would have 3 normal looking plugs and one fouled looking one....
  10. IronNam
    Sir, get some masking tape, a sharpie, and your set of tools and some patience.
    Mark and label all your vacuum lines connected to your intake manifold..... Cuz you know why? Remove your intake manifold! include pictures if you do remove yours and take pictures of it's condition and state. you will see how dirty it can be in there!
    don't forget the handy wire brush too
  11. dirty
    dirty Member
    garner NC
    oh i know its dirty in there. when we had it apart messing with the tps i could see alot of build up in there
  12. dirty
    dirty Member
    garner NC
    pulled the upper intake this afternoon and omg it was dirty. there was a lot more build up in there than i had originally thought. so i m gonna mess with cleaning it out and see what happens then
  13. IronNam
    give this a shot too. Feeler gauges and some basic tools with get your pretty easily.
    I set mine to .008 and .010
    btw, i found my #4 exh valve clearance to be super loose.... scared teh **** outta me.
    I'm not sure what i really did, but i had really bad idle. but when i pulled my manifold plenum off, I also sprayed my coldstart injector and everything else with carb cleaner.
    And this was because my oil filter was stuck.... i eventually got to remove it with a huge-@55 plier and when i did this, my injectors were loose... so i put on new o-rings and before i did that, i sprayed my injectors inside and out with carb cleaner. and sprayed carb cleaner into the injector's port....
    and idk what else i did but my truck idles sooo smooth now... before that, my whole truck shakes at idle and you can see the antennae move.....
    oh yeah, i only had 2qts or less of oil in truck.... o_O :runaway::runaway:
    so i now have 4.5
  14. dirty
    dirty Member
    garner NC
    ill have to lok into that
    might as well while the plenum is off
  15. dirty
    dirty Member
    garner NC
    still plugging away on this slowly but surely
    new egr is in place. with all bolts
    new o2 sensor
    got the intake back from cleaning today
    sent off injectors to luis @ paradies racing for cleaning
    should have them back middle of next week then its reassemble time
    and see what happens. just trying to cover all my bases
    would the cat have anything to do with it running funny?
    if so ill have to do something about it
  16. IronNam
    i think one of your injectors weren't closing all the way. I'm sure itll run better once you get them back
  17. dirty
    dirty Member
    garner NC
    yeah it can only run better than before
    im hoping that all this will fix my problem
  18. dirty
    dirty Member
    garner NC
    alright i got it back together but now it wont start. thought the battery was dead so i put it on the charger and nothing. swapped in a known good battery out of my other truck and nothing. all the lights in the cab and dash come on but when i hit the key the gear light goes out, the radio and clock go off and i hear a clicking coming from the glove box area but no turning over.
    any ideas?? i figure its something stupid but cant put a finger on it
  19. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    check the trigger wire at the starter. its the single little wire going to it. it's not making a good connection
  20. dirty
    dirty Member
    garner NC
    ill have to check that. the power wire to starter is good and has been upgraded to 4ga
