Wanted 20r head complete & intake complete
Discussion in 'Wanted' started by hibillyg, Jan 29, 2011.
  1. hibillyg
    hibillyg Newbie
    I just bought a car with a 20r engine and no head or intake manifold or carb. It seems like someone took it apart to do a valve job and it got separated. I do have the rocker assemble. Any help in getting the parts to get the engine up and running is greatly appreciated. I live in massachusetts..
    Again, Thanks Bill
  2. slacker
    slacker Addict
    Penticton BC , Canada
    84-7m-GTE custom
    where are you ?
  3. oldschool64bus
    oldschool64bus Veteran
    Boise, Idaho
    1983 SR5 4x4
    thats not gonna be cheap shipping :shrug:
  4. hibillyg
    hibillyg Newbie
    I'm in Massachusetts
  5. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    Here's some stuff that may help you out...
    I have a used head that needs to be cleaned up and the #4 spark plug hole re-threaded. Might need 1 or 2 exhaust studs also re-threaded aswell... Block mating surface is a 10, no corrosion... I'd still have it re-surfaced tho. I have to double check if it has fuel pump and power steering bosses...
    I also have the intake manifold that I had cleaned up for a holley carb.
    I dont have a 20R carb only a stock 22R carb, which can work if you get the adapter from LC engineering...
    $50 for the head (stock cam and steel rockers included). You pay shipping, which will be around 25-35 bucks UPS ground...
    $40 for the intake + shipping
    $85 for the 22R carb + shipping
    Let me know...
  6. hibillyg
    hibillyg Newbie
    Hi, thanks a lot . I bought what i needed from Javiar. HeHis parts didn;t need any work to get my engine going.
    Thanks again, Bill
