want the front lower
Discussion in 'Suspension/Chassis' started by 77yoter, Nov 8, 2009.
  1. 77yoter
    77yoter Veteran
    seattle
    77 sr5 shortbed, 81 shortbed, 90 4x4
    ok so i got done with lowering the rear of my truck more and now she is squating about two inchs lower than the front
    so my question is does anyone know how i can drop the front abit more without having to cut the coils more already have about two and a half cut out
    any help would be great
  2. Predracer
    Predracer Toyotaholic
    Conyers, GA
    Long bed 80 2rz turbo machine
    You can clamp them.
  3. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    swap to mk3 supra front spindles, acts like a drop spindle (1in ish) and moves the wheel forward a bit.
    what size blocks are you running in back?
  4. 77yoter
    77yoter Veteran
    seattle
    i have 3 inch blocks with the main leaf and the overload flipped my goal is to have the mud flaps touching the ground and im about an inch away from that happining and im already notched so there would be no clearence issues there
    the mklll that is a third gen correct?
  5. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Yeah. But it does push the wheel forward and it looks a little odd. I read about it and think there are a couple othe little things about that I didn't like. No more 14s for example from the bigger brakes.
  6. 77yoter
    77yoter Veteran
    seattle
    if i cant run my steelies i dont want to waste the money or my time on doing that swap then well damn
  7. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    you could try the ball joint flip, but it IS DANGEROUS.
    dont care what others say, but depending on a balljoint to hold your truck off the ground and handle the weight of the truck is crazy.
    or get ahold of seth @ twistedminis and see if he can make you some drop spindles.
