Want a custom sway bar? Make it yourself! :)
Discussion in 'Suspension/Chassis' started by Gadgedizzle, Aug 13, 2012.
  1. Gadgedizzle
    Gadgedizzle Member
    Northern California
    92 Toy 2wd Reg cab SB Corvette LT1 6-speed.
    Sway bars are made of all kinda stuff.. From Standard cold rolled DOM tubing, to solid round stock that's been heat treated and stress relieved.. What I decided to do is different though...
    I happened to have a friend that had a sway bar for a 96 Camaro SS. it was a few inches too wide, but was MUCH larger than my stock one and I was wondering what it would do for me performance wise. I was also hanging out at Cortex Precision engineering in Sonoma At Sonoma Raceway and nticed one of the mustangs they were working on had a DOM tube sway bar with flat plate arms welded on.. I got to thinking.. What if I just shortened the arms where I needed them, weld them back on in the positions I need them, brace it so they are relieved? I bet I could make my own! So this is what I came up with.. 96 Camaro SS Sway bar for my 89-95 Toyota 2wd. The stiffest thing you're ever gonna find for these trucks, I promise.
    Top - Stock 22mm (solid?) Toyota sway bar
    Bottom - 96 Camaro SS 30mm x 0.195" sway bar. <--This thing is VERY stiff and brings a whole new level of handling to the truck!
    Hope this motivates some of you that have a little ingenuity and ability to go out and actually challenge the norm, and people that say it can't be done..
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    A sway bar of any type has a lot of force ,stress applied to it when corning, any welding on one should be Tig welded & only by a very good welder!!
    The bars I run are chrome-molly spring steel!! :cool:
  3. Gadgedizzle
    Gadgedizzle Member
    Northern California
    I second that.. However it is possible to successfully weld a sway bar to make whatever you need. :)
    PM me, where about do you stay?? I'm in town. Maybe we can bounce ideas back and forth. LMK.
  4. sojayota
    sojayota Enthusiast
    i dig this type hotrodding!!!!!! right on
  5. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    Keep us updated!
  6. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    sometimes too stiff can be a problem, for example.....viagra, if remains errect for longer than 4 hrs consult a physician. and sometimes u just gotta spend the money for quality. its not worth cutting corners. sure there can be a few cheap tricks here n there but to the major important stuff that matters, its best just to pay up. IMHO
  7. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Yes,the last thing you want to happen is to slam your ride into a conner & have a suspension part fail!!
    It just may be the last thing !!!!!:cool:
  8. IronNam
    I would've at least made it solid.
  9. Sal-G.77
    Sal-G.77 Enthusiast
    Palmdale CA
    90 4RUN/22RE/2WD
    Looks good to me !
