w55 swap to w58 transmission
Discussion in 'Engine/Drivetrain' started by Kristian43, Dec 28, 2011.
  1. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Alright guys I need some help. I wanna swap out the w 55 in my 89 for asupra w 58.
    I tried searching for some info but didn't come up with much ?
    I plan on getting a custom drive shaft made,
    So my question is has anybody done this before? And is there a write up on how to do this? As well as what do I need to do this swap?
    So far I know I need:
    W58 trans
    custom driveshaft to mate the w58 to 7.5 axle
    And what else?
    Appreciate the help guys.
  2. knucklehead
    knucklehead Enthusiast
    Mount Pleasant, Tennessee
    No custom driveshaft needed your stock one will work. All you have to do is swap bellhousings and go with it. I've put a 82 celica w58 in a 3rz T-100 that had a w59 and i had to change the speed sensor out of the rear case but it was a direct swap. I've also swapped out a 4 speed for a w58 in a 84-88 truck. You may have some shifter location issues but not a big deal.
  3. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    I did the swap in my 92. Swap the bellhousing,speed sensor and reverse switch and done. While your in there a lightweight flywheel would be good.
  4. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Okay so let me get this straight.
    I can reuse my drive shaft without modification ?
    I also Already have a lightweight flywheel
    Is the 22re flywheel the same diameter as the w58 clutch?
    And does the w58 mount to the stock w55 transmission mount without trouble?
    Thanks again guys
  5. Da_Roach
    NOVA
    I'm using a LCE flywheel and a clutch from my w56 in my w58. Everthing is the same but the bellhousing. The only thing I wound suggest is a new rear tailshaft seal on the back of the trans. Cheap peace of mind.
  6. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    the clutch and flywheel are 1/8" diameter different and a supra pressure plate won't bolt to a truck flywheel BUT the truck clutch will slip onto the supra transmission input shaft.
  7. Vicoor
    Vicoor Newbie
    Manassas, VA
    93 2wd xcab
    in other words,,,
    Use the same clutch you've been using.
    the shifter housing is different and won't accept a truck shifter. you can remove the tail housing and swap the linkage piece inside if you want to retain your stock shifter and location. Also, it's likely that the drive for the speedo is a different ratio and while the tail housing is off you can swap the speedo drive gear.
    Use the later model trans for the beefier internals. You can find more info online.
    Hope this helps,
    Victor
  8. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Any problems with the stock clutch slave cylinder working with the w58??
  9. TRfknD
    TRfknD Veteran
    The Woodlands, TX via (Guahan)
    96 Taco / 05 Tundra
    Shouldn't be a problem once you swap your bellhousing.
  10. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Just thought of another question. Can the w58 bolt to the w55 trans mount?
  11. TRfknD
    TRfknD Veteran
    96 Taco / 05 Tundra
    Yes
  12. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    need a w58 ? I got one :)
  13. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Titan- I've been looking into it. Is it in good shape?
  14. V8_TITAN
    Tampa Fl
    89 std cab
    yeah mine is in great shape, out of the years ive had it in my truck it only has 1000 to 2500 miles.. theres no way there is anymore then that. how much do they sell for around you ?
  15. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Ive seen a couple for around 200 I. can call pick n pull to see what they run there. How much do you think shipping would be to north cali
  16. V8_TITAN
    Tampa Fl
    89 std cab
    Im going to guess around 80 bucks.
  17. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Ill let you know:waytogo:
  18. IronNam
    If you have a manual truck, you can use your same clutch, flywheel, clutch setup (including all cylinders), and you might as well get your clutch job done if it needs one.
    guys with the manual to W58 swap and switched the speedometer gears, did it keep your speedometer correct?
  19. rida4christ
    rida4christ Member
    Hesperia CA
    Hi, i have a 86 mk2 supra and a 95 Toyota pickup im considering this swap on my pickup what are the benefits to this swap? Plus I got other plans for the mk2
  20. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    8% taller 1-2-3 and 5th so it is a pretty even split between the first 4 gears and a bigger overdrive.
