w50 slave cylinder return spring?
Discussion in 'Engine/Drivetrain' started by Henry, Jun 27, 2020.
  1. Henry
    Henry Enthusiast
    Washington State
    The w50 (5 spd) is installed and I'm finishing up a few things. I reinstalled the slave and went to attach the return spring but I don't see an obvious way to attach this. I only have the 4 spd spring and figured it should be the same. Am I missing something? Is it possible this slave doesn't use the return spring like the 4 spd did?
  2. fred heath
    fred heath Veteran
    Raleigh, NC
    My L43 has no return spring on the slave. Everything is hydraulic.
  3. Liquidhandwash
    Liquidhandwash Enthusiast
    Northen VIC
    1980 diesel
    Some have a spring some do not, generally if they have a spring the pushrod will be adjustable
