w50 5speed swap into 69 Hilux
Discussion in 'Engine/Drivetrain' started by kmghawaii, Jul 20, 2012.
  1. kmghawaii
    kmghawaii Enthusiast
    maui, hawaii
    1969 Hilux
    aloha everyone,
    i am about to do a w50 5speed swap into my 69 hilux! i was wondering if anyone else out there has done a 5speed swap? does anyone know where to get aftermarket parts for the w50 such as clutch, short shifter?
    mahalo
  2. '80yota
    '80yota Enthusiast
    Spokane, WA
    '80 Sr5 Long bed
    I have a w56 in my 67 stout...but its behind a 20r. Used the master cylinder from a 20r pickup and slave that was on the tranny. One custom line and wham-o it was done.
  3. williyumz
    williyumz Enthusiast
    I just recently replaced my 4 speed(made noise) on the 8R with a w50 steel case, i used the 8R flywheel(same as 20r), the pilot bearing is the same, used clutch fork/slave from w50, must use 20r clutch to work with w50 front spline shaft, bell housing mates but you have to drill out the two lower so the dowel pins will insert, eventually you'll have to cut the tranny tunnel and custom fab the tranny mounts further back, the e brakes will still work but only have little travel enough to lock the rear, driveline will remain the same length but you will need to replace the driveline yoke with the w50 yoke, thats pretty much all to it.
    Difficulty is 3 out 5 in opinion.
  4. williyumz
    I just recently replaced my 4 speed(made noise) on the 8R with a w50 steel case, i used the 8R flywheel(same as 20r), the pilot bearing is the same, used clutch fork/slave from w50, must use 20r clutch to work with w50 front spline shaft, bell housing mates but you have to drill out the two lower so the dowel pins will insert, eventually you'll have to cut the tranny tunnel for the shifter neck to clear and custom fab the tranny mounts further back, the e brakes will still work but only have little travel enough to lock the rear, driveline will remain the same length but you will need to replace the driveline yoke with the w50 yoke, thats pretty much all to it.
    Note that a w55 aluminum case will be the same process but may differ in tranny crossmember mounting point.
  5. kmghawaii
    maui, hawaii
    1969 Hilux
    thanks! i actually finished it in a total of 8 hours. not sure of thats long or not haha but it super sick! i will post some pics in my build thread soon! needs to be updated!
