vcv
Discussion in 'Engine/Drivetrain' started by toyotanator, Mar 8, 2010.
  1. toyotanator
    toyotanator Member
    cleveland ga
    77 pickup
    the nipple broke off the vacuum control valve tonight and was wondering if you plug the hole and put a F shaped vacuum line adapter in would it run like it did or like crap
  2. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    super glue
    ive also seen bic pen tips used, not the ink but the tapered casing part.
    only the brave F with the vac lines.
  3. toyotanator
    toyotanator Member
    cleveland ga
    77 pickup
    well the F connector works and runs like it did
    i had to think of something before the part store closed so i can get to school tomorrow
    that part is only a factor part and i dont wanna pay a arm and a leg to get a piece i can rig together to work
  4. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    sounds good like a good temp fix. maybe grab a spare at the junkyard to swap over in case your fix fails.
  5. toyotanator
    toyotanator Member
    cleveland ga
    77 pickup
    thanks standardbyker
    i'm actual trying to find a job and get a weber so i dont have to worry bout it
